CGT Roof DTC 02461
Old May 7, 2022 | 07:32 PM
George7013's Avatar
George7013 is infamous around these parts
CGT Roof DTC 02461
Convertible top for my CGT stopped working the other day. It opens up until the point where the tonneau cover has to open that it stops. the top does have some fraying where in the past, the tonneau cover has brushed against the top. It seems as if the rear bow does not move enough out of the way for the tonneau cover to open. If I hold the button, the convertible top motor continuously runs but the tonneau cover does not open. I pulled codes and the only thing I saw was 02461 which said "Right linkage flap position sensor- implausible signal." I have an Autel mp808 scanner. Not sure what the problem could be. Thanks in advance
Old May 8, 2022 | 03:55 PM
tteplitzmd's Avatar
5 Year Member
tteplitzmd is infamous around these parts
What year is your GTC?
My 2013 had a similar problem which fortunately proved to be two loose hinges rather than sensors or relays.
Seems most people are not so lucky as Gen 1 GTC has a known problem with the top. Gen 2 seems to be not so much,
but having seen these tops being repaired in the dealer's shop, they look to me like a Swiss watch taken apart.
ContinentalGT05
Bentley
Oct 27, 2016 10:01 PM
ToofDoc
Oct 22, 2015 10:02 PM
spg993tt
Oct 1, 2009 09:39 AM
Brian Haske
Jan 22, 2008 01:06 PM
