Brake Squeal - 2013 GT
Old Oct 20, 2023 | 06:31 AM
Montyjn's Avatar
Montyjn is infamous around these parts
Anyone else have this issue with their continental and found a way to rectify? Sounds like its front brakes on mine. Have had them stripped down and cleaned, but the issue just came back..
Old Oct 21, 2023 | 02:56 PM
Randy V's Avatar
5 Year Member
Randy V is infamous around these parts
Are you sure it is not the pads getting to end of useful life? the pads have steel elements that create a squeeling sound when contacting the rotor as an autitory way of letting you know the pads are getting thin. The pad wear sensors on the Bentley is famous for not sending an error message to the system.
Alternatively you can try using the standard pad bed in procedure to remove any glazing on the pads that can cause squeeling.
Accelerate the car (on a straight empty road) to 60 mph, then apply the brakes vigorously without engaging anti-lock - until the car comes to near zero speed. repeat this exactly for 5-6 more cycles.
Then drive the car are higher speed without using the brakes in order to cool the rotors. Be aware that after the 6 cycles the brakes will experience extreme fade until they cool down, so you must do this on a road that does not encounter other vehicles.
Old Oct 31, 2023 | 01:36 AM
Montyjn's Avatar
Thanks for this. I had the brakes looked at by a specialist and they were happy with the overall pad thickness etc, but I'll do another visual check to confirm.
Cheers for that information on bedding in. I hadn't heard that before. I think I know somewhere local where I can try the procedure. Will report back!
Montyjn
Bentley
May 3, 2023 04:54 AM
Kingwu
Bentley
Jan 2, 2023 08:01 PM
panamera_lou
Bentley
Mar 20, 2022 09:42 AM
ignaciocrespo
Bentley
May 30, 2021 05:30 AM
lalaw5000
Bentley
Jul 12, 2018 03:14 PM
