CD Player question
Old Aug 3, 2025 | 04:01 PM
09Speed's Avatar
Community Builder
09Speed is infamous around these parts09Speed is infamous around these parts
CD Player question
Does the CD player need any programming if you swap one out? Previous owner had removed the CD player and I bought a used one on EBay and it plays a CD fine, but will not switch to the next CD, nor will it move to the CD you select on the radio. The CD player will have a blinking red light corresponding to the CD selected, and it will show CD number and title list on info screen, but won't play. If I try and say select #3, it will just have a blinking red light on #3 at CD unit, but it won't play, if I eject #3 and then reload #3 it will play-same with all of the CDs 1-6. When it finishes a CD it also will not switch to next CD, same thing happens, next CD's light is blinking on CD Player and info shows correct #, but won't play.
Old Aug 4, 2025 | 07:53 AM
09Speed's Avatar
Community Builder
Nobody with any info here? @Johnny Hotspur do you know?
Old Aug 4, 2025 | 06:02 PM
09Speed's Avatar
Community Builder
i ran a VCDS scan and it shows a mechanical Failure-intermittent. Any ideas of what would cause this?
Name:	CD Player fault code.jpg
Old Aug 6, 2025 | 01:18 PM
09Speed's Avatar
Community Builder
Never mind- After cycling it about 20 times it finally loaded the next CD and all works now, think the arm was just stuck for transport
MRCW
Aug 11, 2020 08:21 AM
KwlAznKid
Jun 15, 2009 04:28 AM
O-Ace
Sep 15, 2006 05:00 PM
