USB swap of cigarette lighter
Old Feb 22, 2026 | 08:31 AM
zissis's Avatar
5 Year Member
zissis is infamous around these parts
Do you guys think this would fit to replace the 2010 continental cigarette lighter in the front and rear of the car?
https://www.newegg.com/p/359-04A2-000B8
Old Feb 22, 2026 | 10:39 AM
BruceR's Avatar
5 Year Member
BruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud ofBruceR has much to be proud of
You can buy the exact same thing in a plug-in version from Walmart for $12 and you get 2 of them!
https://www.walmart.com/ip/Car-Charg...sRedirect=true
Or just one for $7 from Amazon:
Amazon Amazon
Old Feb 22, 2026 | 10:43 AM
zissis's Avatar
5 Year Member
I am looking for a flush look that replaces the existing socket. I settled on this one since the Bentley lighter has a 25 MM hole and this requires a 22MM hole minimally. My existing socket is worn out so it needed replacement anyways
https://www.ebay.com/itm/388563744865
Old Feb 25, 2026 | 01:17 PM
CUE99T's Avatar
CUE99T
I was looking at doing something similar until I changed to the Grom Audio kit and I have usb via that now. But I did buy a USB replacement like the one you have but just never fitted it. You need the cigarette removal tool I think, its just easier with it and pennies to buy. Tool
Old Feb 25, 2026 | 01:40 PM
zissis's Avatar
5 Year Member
I am not spending time doing the refit. Sending the 2 usb ports and car to my mechanic. He will remove the center console, remove the entire cigarette lighter housing and replace it with the USB one and wire it up. That is a pretty nifty tool though.
Old Feb 25, 2026 | 01:48 PM
BruceR's Avatar
5 Year Member
And if that universal tool doesn't work you can get the VAG specific one for only $380!
Amazon Amazon
yanacha
Bentley
Apr 12, 2019 01:13 AM
F430Spider
Dec 7, 2010 04:21 PM
Shotcaller
Oct 6, 2010 07:01 AM
vtandon
Other Japanese Supercars
Jun 29, 2010 10:08 AM
