1M dyno'd @ 331whp/362wtq
Old May 25, 2011 | 08:27 PM
MCJ's Avatar
MCJ
MCJ is infamous around these partsMCJ is infamous around these parts
Thumbs up 1M dyno'd @ 331whp/362wtq
http://www.youtube.com/watch?v=FRKrp...layer_embedded
Equipped with the company's N54 twin-turbo 3.0-liter direct injected inline-6, the 1 Series M Coupe is rated by the factory (that is, at the flywheel) at 335 hp at 5,800 rpm and 332 lb-ft from 1,500-4,500 rpm.
Peak torque rises to 370 lb-ft during an overboost period, the command for which is not driver-activated. That little "M" button on the steering wheel sharpens the throttle response, and nothing more.
We'll assume the overboost function was live because, well, just have a look below at the result from the Dynojet chassis dyno (see above).
Whoa! Now that's some torque. From 2,500-4,500 rpm, there's more than 350 lb-ft on tap, and then it rolls off linearly between 5,100 and 6,700 rpm. It's pretty much done at that point, and the fuel cut arrives at 7,000 rpm. Peak power of 331 hp arrives at 5,150 rpm.
Torque peaks at 362 lb-ft and hits early in the rev range. As explained in a previous post, it's nigh unto impossible to replicate on a chassis dyno the drawn-with-a-laser-level torque plateaus that manufacturers provide for their turbo cars.
While BMW says it reaches peak torque at 1,500 rpm, you'll never achieve that result in the real world unless you wood it at 1,000 rpm in 5th or 6th while climbing a hill. No matter, since only a complete toolshed would drive an M car -- or any car -- that way. Downshifting. Learn it.
So, no, the 1 Series M Coupe definitely doesn't provide the power delivery characteristic we're used to seeing in M cars. Revving it to red doesn't provide the rush it once did. This one's all about midrange. But, man, there is an awful lot of grunt here.
This was no fluke outlier of a dyno run, either. Check out all six pulls here. They're all pretty tightly clustered, and there was no discernible trend of heat soak or degradation as the runs progressed. All the variation you see was random.
Speaking of heat, it is part of the reason the torque noses over around 5,200 rpm on these engines. The mixture is richened up and boost ramped out in order to keep exhaust gas temperatures at a level that will keep the catalytic converters and turbine componentry alive for the duration of the 150k mile life required by EPA.
BMW tends to rate its turbo sixes pretty conservatively, as we've seen similarly robust results like this on previous dyno tests of the 335i and 135i. It's likely that BMW employs a very conservative (read: hot) intercooler temperature when performing the power certification test. This would tend to de-rate the output claimed by the manfacturer.
Waitasec, the 135i has a turbo N54 and so does this thing. Beyond the peak numbers, what's the difference in sauce delivery?
Glad you asked. Here's the 1 Series M Coupe dyno result overlaid with our old 2008 BMW 135i long-termer that we tested on this very dyno a while back.
The 1 Series M Coupe just smacks down the 135i everywhere in the rev range. In particular, though, look at that additional meat slab of torque that the 1 Series M Coupe provides between 2,500 and 5,200 rpm.
So what do you say, fair IL reader? Is a small M car with boost the kind of car for which you hunger? Not that you really have a choice, as they're all headed this direction. In fact, contrary to what you've heard recently, we've got it on good authority that the next M3 is getting a hotted-up version of the N55...
--Jason Kavanagh, Engineering Editor
http://blogs.insideline.com/straight...s-m-coupe.html
Old May 25, 2011 | 08:43 PM
czechchamp's Avatar
czechchamp has a spectacular aura aboutczechchamp has a spectacular aura aboutczechchamp has a spectacular aura about
That's impressive IMO
Old May 26, 2011 | 12:11 AM
adamls2's Avatar
adamls2 is a jewel in the roughadamls2 is a jewel in the roughadamls2 is a jewel in the rough
id hit it....cant wait to see what COBB tuning is going to do with this
M3 killer maybe??
Old May 26, 2011 | 06:14 AM
BAD ASS TA WS6's Avatar
BAD ASS TA WS6 is a glorious beacon of lightBAD ASS TA WS6 is a glorious beacon of lightBAD ASS TA WS6 is a glorious beacon of lightBAD ASS TA WS6 is a glorious beacon of lightBAD ASS TA WS6 is a glorious beacon of light
Excellent!!!
Old May 26, 2011 | 08:39 AM
SpoolMasta's Avatar
SpoolMasta is infamous around these parts
The n54 is a awesome engine, I just got a 335i and its lightyears faster than my e46 m3 in the straights.
So with some m-suspension bits and a M diff, I could say m3 killer for sure!
-Travis
Old May 26, 2011 | 08:55 AM
sfhondapilot's Avatar
sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !sfhondapilot Is a GOD !
-Travis
I agree, the n54 powerplant is great and the tuning potential is pretty impressive.
But this really does encapsulate what I associate with an M. A powerplant that just invites you to wind it out to redline over and over again, staying in a gear the keeps the tach above 4k.
Old May 27, 2011 | 09:39 PM
og risker's Avatar
og risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud ofog risker has much to be proud of
Nice numbers. High reving NA engines may be a thing of the past sooner than we think...sigh
Old May 28, 2011 | 10:35 AM
DarrinB's Avatar
DarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to allDarrinB is a name known to all
Is this basically the 335i motor with a more aggressive tune?
Old Jun 1, 2011 | 01:36 PM
tightie's Avatar
tightie is infamous around these parts
Nice.
Old Jun 2, 2011 | 07:11 PM
Supramonster's Avatar
Supramonster is infamous around these parts
Very nice numbers.
Emre@Esmotor
Oct 19, 2015 12:06 PM
Oct 2, 2015 02:23 PM
ModBargains.com
996 Turbo Vendor Classifieds
Oct 1, 2015 11:48 AM
