BMW 550i (F10 Chassis) Eibach Pro-Kit Performance Springs Just Released
Old Jul 11, 2012 | 10:25 AM
GMP Performance's Avatar
Site Sponsor
As an Authorized Eibach dealer, we just received information regarding the release of Eibach's Pro-Kit Lowering Springs for the BMW 550 model F10 chassis and wanted to share the details with you guys.
THE FIRST STEP IN SUSPENSION PERFORMANCE
Eibach PRO-KIT is the perfect answer for most frequently-driven street cars. It's our legendary spring system that dramatically improves both a vehicle's performance and appearance.
PRO-KIT lowers your 550i's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with Plus-1 or Plus-2 wheels and tires, the Eibach PRO-KIT is the finishing touch to a winning recipe for performance. PRO-KIT also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Pro-Kit #20113.140
  • High Performance Handling and Aggressive Good Looks
  • Lower Center of Gravity — Lowers 550i 0.8" Front and 0.8" Rear
  • Stop Quicker, Corner Faster and get Better MPG
  • Excellent Ride Quality
  • Million Mile Warranty
Every Eibach PRO-KIT is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, PRO-KIT provides the ultimate balance to take your passion for driving to a whole new level.
TECHNICAL INFORMATION
FRONT:
OE rate: 40 N/mm (228 lbs/in)
PK rate: 45 N/mm (257 lbs/in)
Tubing: None
Bump-stop: OE
Damper: OE
OE wheel center to fender: 395 mm (15.6 in)
PK wheel center to fender: 375 mm (14.8 in)
Front Alignment:
OE Camber = -0.5 deg (+/-0.4 deg)
OE Caster = n/a (Cross Caster = 0 +/-0.5 deg)
OE Toe = 0.08 deg (+/-0.03 deg)
PK Camber = -0.5 deg
PK Caster = 6.4 deg
PK Toe = 0.08 deg
Approximate installation time: 2.0 hr
Front:
REAR:
OE rate: 23 N/mm (131 lbs/in)
PK rate: 34 N/mm (194 lbs/in)
Tubing: None
Bump-stop: OE
Damper: OE
OE wheel center to fender: 391 mm (15.4 in)
PK wheel center to fender: 371 mm (14.6 in)
Rear Alignment:
OE Camber = -1.8 +/-0.1 deg.
OE Total Toe = 0.12 deg. total +/-0.03
PK Camber = -1.9 deg.
PK Total Toe = 0.12 deg
PRO-KIT can be aligned to OE specifications.
Rear:
Old Dec 19, 2013 | 10:59 PM
Kendall993's Avatar
Kendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to beholdKendall993 is a splendid one to behold
Do they make an aftermarket sway bar? Do you have any recommendations on ECU tunes for the 550? Thanks
Old Jan 9, 2014 | 02:03 PM
Site Sponsor
Contact us if you're interested in more information about this cool kit!
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
The Oss
Aug 24, 2015 08:19 PM
