e46 M
Old Mar 24, 2013 | 08:53 AM
wilmar13's Avatar
wilmar13 is infamous around these parts
Originally Posted by bennnz0
I'll be tracking the car too. I'm worried about long term reliability towards forced induction rather than a built motor.
Revs will wear out the NA build you make... heat will kill the FI.
As long as you upgrade the cooling capacity, going FI is probably a bit more reliable way to make higher levels of power once you get over a certain threshold. The stock S54 makes over 100hp/liter at the crank already and has piston speeds that approach Formula One engines at max rpm. Not much blood to squeeze from that rock, without a cost to reliability and longevity.
If you want reliable, stay NA with basic mods and make sure everything is maintained.
If you want big power and reliable, don't dismiss FI. It will be cheaper and more reliable to reach higher power levels.
If you want badass NA power, then go for broke. Nothing worthwhile is easy and big power NA build is the sexiest way to go, but also the most expensive.
Feelgood MD
Mar 24, 2016 09:35 AM
ECS Tuning - BMW
BMW Vendor Classifieds
Oct 28, 2015 10:48 AM
Enemy
Oct 24, 2015 04:14 PM
MtnTempo
Sep 14, 2015 06:49 AM
frayed
Jul 1, 2004 08:12 PM
