2011 BMW 550i, leaking oil, thoughts?
Old Oct 27, 2013 | 05:20 PM
baziturbo's Avatar
baziturbo is infamous around these partsbaziturbo is infamous around these parts
Hey Fellas, noticed my 2011 BMW 550i leaking a few drops of oil. Engine looks clean. Any thoughts?
Thanks!
Bazi
Old Nov 6, 2013 | 03:50 PM
Fkim011's Avatar
Fkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant futureFkim011 has a brilliant future
Bazi,
I had the same thing happen to me on my 2011 550M sport. I thought it was a drain plug but it happened to be some kind of oil reservoir that needed replacing.
Old Nov 8, 2013 | 02:11 PM
redrocket265's Avatar
redrocket265 is infamous around these parts
There are literally DOZENS of common places oil could be leaking from; are you able to remove the belly pans and see specifically where? And if not, can you provide us with a general area that the leak is coming from - i.e. front engine center, rear driver side of engine, transmission area, etc?
The most common areas I've seen leak on those engines are the lower oil pan and/or drain plug. A much more common leak on those (assuming it wasn't something caused by a bolt left loose or something to that effect) would be the transmission; how certain are you that it's engine oil?
Jul 29, 2019 11:13 AM
Senatorblutarsky
Aug 28, 2015 12:44 PM
gulf gt
Aug 27, 2015 10:27 AM
PelicanParts.com
BMW Vendor Classifieds
Aug 25, 2015 03:55 PM
