S55 E-Tronic Tuner for BMW M4
Old Jan 15, 2015 | 09:49 AM
GMP Performance's Avatar
Site Sponsor
S55 E-tronic tuner 550 HP / 560 lb-ft tq
ESS E-tronic provides safe, simple to add power to the already potent F8X M series. Unlike other products on the market E-tronic is a sophisticated multi channel controller that has RPM and MAF intergration. This provides for full control of boost at all RPM ranges and proper AFR calibrations without the need to splice into any factory wiring. OEM grade hardware is used to provide high quality, safe, reliable power with excellent driveablility. Pre-set calibrations provide for a very simple installation without the need for setup or adjustments once installed. E-Tronic can be disabled or removed at anytime allowing customers to keep factory warranty.
Order Here
Three goals are to be meet before any ESS engine related performance product is released for sale :
1. Extended computerized load dyno test which simulates driving so hard that it is just not possible to drive this hard in real life.
2. Development cars through a 50000 mile (80000km) long term test which involves track driving, extreme heat and cold testing, high-speed Autobahn driving for extended periods, and normal everyday driving.
3. Car must have factory like or better drive-ability and smoothness and it must develop the extra power in a perfectly balanced manner.
When we meet these 3 goals with 100% success then, and only then, the product is released for sale.
What separates ESS from the competition:
-Standard 2 year/unlimited mileage warranty on all street supercharging systems.
-Excellent technical support from trained, knowledgeable, and enthusiastic personnel.
-True OEM quality fit and finish, and designed to fit under the factory hood without any fabricating.
-Designed for maximum performance at safe boost levels on stock unmodified engines.
-Fully OBD-II diagnostics compatible.
-Fast service and support.
-100% complete systems, even down to the wire ties, making installation and ownership easy and trouble free.
Old Feb 12, 2015 | 01:04 PM
Site Sponsor
We preformed a local install of one of these units.. Power difference is amazing!!!
BMW //M
Oct 5, 2015 12:00 PM
Velgen
BMW //M
Sep 10, 2015 01:12 PM
WheelB
BMW //M
Sep 10, 2015 11:40 AM
