Thinking of picking up a E36 M3. Need advice
Old Oct 24, 2005 | 01:07 PM
osj911's Avatar
osj911 is infamous around these parts
So I'm considering picking up a e36 m3 coupe and wanted to get any advice from people in regards to their reliablitity and any common problems they have. Also are there large benefits in getting these cars with lower miles vs. higher miles. Either way I'll be looking for 70k mi. or less. Feel free to pitch in!
Thanks in advance
Old Oct 24, 2005 | 01:35 PM
msb2tg996's Avatar
msb2tg996 is infamous around these parts
get a 95' it's easier to mod.
Old Oct 24, 2005 | 01:59 PM
Life Dies's Avatar
Life Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud ofLife Dies has much to be proud of
5 years ago, this statement held truth. Today, tuners have perfected the OBDII reprogramming.
If you get a 95, immediately replace the waterpump as the impeller is plastic.
Depending on the mileage of the car, regardless of year, the rear toe bushings will likely need to be replaced. Inspect RSM's, too.
I've had two e36 m3's over the past 6 years and they are such a thrill - you will enjoy this car greatly. I've been out of the scene so long, I forget what else there is to tell you. If i think of anything I'll let you know. Great car!
Old Oct 24, 2005 | 07:25 PM
mooty's Avatar
mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !mooty Is a GOD !
__________
actually if you have more than 70k miles on any year m3, replace all of above and radiator as well. you don't want them to fail, overheat, and warp the head and even the block.
95 is particularly prone to headgasket problem.
_________
if u intend to drive it hard. replace ALL the bushings, engine, tranny and diff mounts.
Old Oct 25, 2005 | 07:24 PM
LIL RAJA's Avatar
LIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant futureLIL RAJA has a brilliant future
buy mine, it's 95 and i am selling it relatively cheap.
Old Oct 26, 2005 | 02:19 AM
zameil's Avatar
zameil is infamous around these parts
Having just picked up an e36 mspec I can say that as a daily driver they're great. The only prob I had was the air con pump which died three weeks after I got it. $1000.00 later it's fine.
They respond to mods really well, so far I've put a full reiger system on mine and vanos along with a re tuned ecu and TCM (traction control module).
Like I said, as a daily driver that you can have fun with they are great bang for your buck.
My "M" spec.
Please note Not an M3
Old Nov 3, 2005 | 12:42 PM
95RogueM3's Avatar
95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of95RogueM3 has much to be proud of
Originally posted by Life Dies
[B]If you get a 95, immediately replace the waterpump as the impeller is plastic.
As are 96 pumps and some 97s. Its a good thing to replace regardless.
Do you mean RTAB? (Rear Trailing Arm Bushings) if so, they will be shot by 75k miles, as will the RSM (rear shock mount).
The radiator neck is plastic and tends to crack soon after you cross the 100k mile mark...
The 95s had 7.5" wheels stock all around with an unstaggered tire setup, while the 96+ models have a 7.5 front wheel with an 8.5 rear on a staggered tire setup.
95s dont have traction control, 96+ do
Red and Yellow 95s (Dakar 1 and Mugello, respectively) didnt have clearcoats..just single stage paint.
The suspensions tend to be shot by 75k-80k miles depending on the way the car was drive.
If you have more questions, please feel free to post them..I think I can pretty much field any of them..
jrblackbox
914/914-6
Nov 19, 2015 08:01 AM
Enemy
Oct 24, 2015 04:14 PM
HolmaN
Aug 19, 2015 07:32 PM
