Complete BMW M3/M4 (F80/F82) Brake Option Under One Thread
Old Feb 20, 2016 | 06:33 AM
RacingBrake's Avatar
RacingBrake is infamous around these parts
1. Stock Iron Rotor Replacement
380x32/370x26mm (vs. OE 380x30/370x24)
Thicker rotors provide extra thermal capacity and allow you to run at lower braking temperature.
http://www.racingbrake.com/RB-Two-pi...bmw-irk-13.htm
2. Track Duty Front Rotor Kit (CCB front 6 pot gold calipers included)
380x36mm
This set up is designed for heavy/track duty and must be installed with CCB 6pot calipers.
http://www.racingbrake.com/RB-Two-pi...-ca-p/2474.htm
3. CCB Replacement & BBK (for 4/2 pot)
390x36/390x30mm (vs. CCB 400x38/380x28mm)
This is a bolt on BBK for standard iron brake, and also for CCB converting to iron rotors (Calipers can be deducted if you already have CCB).
Note the front rotor dia is reduced to 390mm to allow more clearance and avoid wheel damage, while the rear is up-sized to 390mm for a more balanced brake.
Rotors are specifically designed to have wide annulus to accommodate CCB brake pad (M3/M4's 77mm and M5's 86mm) which is significantly wider than Brembo GT/GTR, and Stoptech brake kits.
http://www.racingbrake.com/RB-Iron-T...bmw-irp-04.htm
moje911
Feb 24, 2016 03:22 AM
PelicanParts.com
Feb 10, 2016 11:54 AM
Jonhunt
Jan 30, 2016 11:58 AM
nitrorocket
Jan 23, 2016 06:52 PM
rakib1981
911
Jan 22, 2016 08:13 AM
