My Dinan SC M3 new INTERIOR and ENGINE BAY PICS
Originally Posted by NAPO
WOW... That's an amazing machine!! Your M3 is by far the most beautiful and well put together M3 I have ever seen! Great choice on all the mods... Your car is as close to perfect as possible!
Great job on the pics... They are awesome!
C&D article with stats.
http://www.caranddriver.com/features...-m3-page2.html
12.9@112. You can run close to a 997S with your 107 hp and 33 lb/ft more and only weighs 90 lbs more than a 997S.
Originally Posted by keyser_soze
Just curious. How much boost that thing runs? If its sub 7lbs, couldn't you add a FMIC and use a smaller pully to make little more boost safely?
http://www.dinancars.com/NewProducts.asp#106
Originally Posted by PorscheC4
That def looks great. How about performance? What's she run? High mid to high 12's? I saw the R&T or C&D article on the dinan sc and it didnt seem to yield the numbers i would have liked but great product and quality. Very nicely done.
- Dinan Supercharger Stage 1 Kit (NO intercooler)
- Dinan exhaust (muffler only)
Headers, clutch, flywheel, rear differential, section 1 and 2 are ALL STOCK.
Since this dyno, I installed the Evosport headers, high flow cats and Milltek full exhaust system. Will do another dyno pretty soon.
BEST HP: 371.03 hp at the wheels; with 17% drivetrain loss = 447 hp at crank
BEST TQ: 263.31 ft/lbs at the wheels; with 17% drivetrain loss = 317 ft/lbs at crank
BTW, I did a total of 7 runs, the first 5-runs were wasted because they couldn't get the rpm reading.
Comparison with a slightly modded M3 (not sure of the mods - maybe chip and exhaust):
BTW, here's another pic of the steering wheel:
And just got the UUC shift **** with matte-silver insert to replace my current one with blue insert:
very nice indeed
Very nice power curve (its actually power line as it never curves down!
) Yes I assumed its low boost. I assume Dinan did this since the motor is high compression so with/without intercooler you can't run so much boost. I think this is great setup sepcially for a daily driver. I bet its a fun ride.
As always if you wanted get crazy with it I assume you could pull the motor lower compression and raise boost via your supercharger or go turbo.
Cheers
) Yes I assumed its low boost. I assume Dinan did this since the motor is high compression so with/without intercooler you can't run so much boost. I think this is great setup sepcially for a daily driver. I bet its a fun ride.As always if you wanted get crazy with it I assume you could pull the motor lower compression and raise boost via your supercharger or go turbo.
Cheers
