Turbo E46 M3 on street tires goes 11.6 @ 129
Old Jun 25, 2007 | 03:45 PM
  #61
Divexxtreme's Avatar
Originally Posted by lax01
lol did you just compare an Turbo E46 M3 to a F1 car? lol
Only because you requested it.
I ask you to show me one simple thing...show me one professional road race team out there that is running a 1000whp racecar...go for it/
Old Jun 25, 2007 | 03:46 PM
  #62
Originally Posted by Gabriel
3300 pounds are quite hard to control while putting down 1000hp with conventional vertical shocks and springs.
In an F1 car 80% of the mass of the car is within 30 inches from the ground right in the middle of the 4 wheels and controlled with pushrod suspensions... An m3 is about 58 inches tall, it's engine is in the front at the same height as the rotational centre of the wheels and at 1000hp it probably has about 3 times the torque of the F1 car to put down while suffering from weight transfer, worse wheelbase/track analogy...
Power/weight ratios say nothing about the roadcourse.
At the GP of Spain this year Massa took the pole position with 1:21.421
At the MotoGP of spain in the same track Rossi took the pole position with 1.41.840...
A Yamaha YZR-M1 makes about 250hp and weighs 150kg (without rider)
A F1 car makes about 900hp and weighs 600kg (without driver)
the ratios are: 1.66 for the bike and 1.5 for the F1 car yet the F1 car is 20 seconds faster...
More rubber on the ground. F1 cars always beat bikes.
Old Jun 25, 2007 | 09:48 PM
  #63
lax01's Avatar
lax01 is infamous around these parts
I think Gabriel summed up why thats a pretty stupid comparison...
Old Jun 26, 2007 | 04:16 AM
  #64
Ahhh, but not nearly as stupid as your original question, which prompted it.
Old Jun 30, 2007 | 08:52 AM
  #65
Monaco's Avatar
Monaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond reputeMonaco has a reputation beyond repute
Unfortunately, you're not very good at it. A couple things:
-You mention the tires having to be drag tires. I use them on my P-car, and my car would still outhandle your M3. Trust me on this, I've owned two M3's. Also, drag tires aren't requied. You can run r-compounds as well...which handle and stop better than any street tire on the planet. Plus, they can hook up some very serious power.
-You wanted to know which race teams are running 1,000 rwhp? 1,000 rwhp in a 3,300 lb M3 is a rear-wheel power to weight ratio of around .31. An 800 rwhp Formula 1 car, which only weighs around 1,181 lbs (minus the 150 lb driver)...has a rear-wheel power to weight ratio more than double that...at .67.
For an M3 to equal the rear-wheel power to weight of a F1 car, it would have to have 2,150 rwhp. So there you go. There's the professional race teams you asked for. Many of them, actually.
Different strokes for differeen folks. Don't knock something until you've tried it.
Actually you've just compared the RWHP of the M3 to the crank hp of the F1 car, but I get your point!
Old Jun 30, 2007 | 08:55 AM
  #66
LUISGT3's Avatar
What is the fastest 1/4 miles time for an E46 M3?
Old Jul 1, 2007 | 02:55 AM
  #67
1q2w3e4r's Avatar
1q2w3e4r is infamous around these parts
11.6@129 as I understand it.
Old Jul 1, 2007 | 06:27 PM
  #68
Negative. The 2005 F1 cars with V-10's developed 960 crank HP...thus giving them 800 rwhp.
But yes, I'm aware the new 2.4 liter V-8's make significantly less power.
Old Jul 1, 2007 | 08:32 PM
  #69
Origyns 973's Avatar
Origyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to beholdOrigyns 973 is a splendid one to behold
I highly doubt the conversion factor for a formula one car is that huge, you have to remember the clutch on a formula one car is about the size of a cd, as well as everything being carbon fiber etc.
Old Jul 2, 2007 | 04:49 PM
  #70
You're probably right. They probably made 850+ to wheels. Thanks.
Old Jul 3, 2007 | 08:03 PM
  #71
Chaseme's Avatar
Chaseme is infamous around these parts
Better braking ability too (due in part to more rubber).
Old Jul 20, 2007 | 08:51 AM
  #72
joyride's Avatar
joyride has a spectacular aura aboutjoyride has a spectacular aura aboutjoyride has a spectacular aura about
nice, but i cringe at the thought of rebuilding the s54 block.. $$$
Old Jul 20, 2007 | 11:43 AM
  #73
SCM3's Avatar
SCM3 has a spectacular aura aboutSCM3 has a spectacular aura aboutSCM3 has a spectacular aura about
Its not too bad, not even close to a porsche build.
Old Jul 20, 2007 | 07:04 PM
  #74
Gusagain's Avatar
Gusagain is infamous around these parts
^^^ nothing like the old days of building an old Chevy or Ford either thou I would guess -- what does it run Taz , just to storke out an inline 6 for our Bimmers?
COBB Tuning
Nov 9, 2015 08:02 PM
alevine
Nov 4, 2015 10:05 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Oct 6, 2015 05:20 AM
BenTT
Aug 19, 2015 05:16 PM
