:: ECS Tuning :: E8X 135i ECS 2-Piece Brake Rotors
Subscribe
May 15, 2012 | 01:20 PM
Are you ready to take your brakes to the next level?
Light on weight. Long on looks. All new ECS Tuning 2-Piece rotors combine the natural advantages of a cast iron braking surface with the weight savings and rapid heat dissipation of an aluminum hat. Cast iron-gray and matte black hats create an eye-catching contrast that looks great with painted calipers behind open-faced alloy wheels. These beauties have all the extras: black anodized hats, cross-drilled and slotted brake faces; non-braking surfaces painted for corrosion resistance.
Features include:
  • Aluminum hats: To save weight, each rotor ring is bolted to a lightweight aluminum hat made from high quality 6061 aluminum, and hard anodized with an attractive matte black finish that is both durable and corrosion resistant.
  • Gray cast iron rings: Long known for its wear resistance and stable friction characteristics, cast iron is favored for brake rotors due to its ability to absorb and dissipate large amounts of heat.
  • 2-Piece construction: Conventional rotors are unable to cope with the stress of drastic heat fluctuations and are prone to warping. ECS 2-Piece semi-floating rotors allow the radial expansion of the rotor ring - preventing warping.
  • Directionally veined: Conventional 135i rotors are straight-veined, and rely on an inefficient centrifuge-like effect to evacuate hot air from within the rotor. ECS 2-Piece rotors feature curved, directional veins that accelerate air away from the rotor at a higher velocity, leading to consistent, rapid cooling.
  • Drilled and slotted: 2-Piece rotors are cross drilled to promote cross ventilation for improved cooling as well as slotted to clean brake pads and carry away water and brake dust. Cleaner brake pads result in faster, more consistent stopping. Drilled holes are chamfered while slots are machined with a ball end mill - both to prevent cracking that may be present on improperly machined rotors.
  • Overall weight savings: This particular ECS 2-Piece rotor weighs only 17.8 lb compared to a stock 135i rotor (22.5 lb) and a BMW Performance 135i rotor (21.4 lb). Lighter rotors reduce unsprung weight and rotational mass to improve both braking and suspension performance.
Click HERE to order your 135 two piece brake rotors
Reply
Jun 12, 2012 | 12:53 PM
Direct bolt-on replacement rotors for your 135i at 20% less weight!
Click HERE to order today!
Reply
Jun 22, 2012 | 09:01 AM
Stock 135i rotor 22.5 lb
BMW Performance 135i rotor 21.4 lb
ECS 2-Piece Rotor 17.8 lb
Reply
Jun 28, 2012 | 12:04 PM
Put your brakes on a diet, upgrade to ECS 2-Piece Brake Rotors today!
Click HERE to order
Reply
Nov 13, 2012 | 02:45 PM
Reply
