:: ECS Tuning :: M Control Arm Upgrade|E8X 1 Series|E9X 3 Series
Wanting more out of your BMW without having horrid ride quality? This is not only an extremely common handling upgrade, but one of the best upgrades you can do. These control arms are much sturdier than your factory units and feature much stiffer bushings and ball joints. Not only does this kit give you an extremely effective upgrade, it's the perfect excuse to get rid of your factory arms that are at the edge of being road worthy.
You will notice much more precise handling, a sportier ride, and these arms will add around .75 degrees of negative camber to the front of your BMW! Also included is an M3 headlight leveling rod which is needed to get the job done.
Creak. Moan. Shimmy.
If any of these words apply to your BMW suspension, we have the cure. Bolt on a meaty lower control arm kit, straight from M Series cars. If you're tired of loose ball joints and cracked or hardened suspension bushings, these robust arms will cure the poor handling, harsh ride, and uneven tire wear they cause.
Choice is good, so we're offering complete kits from OEM supplier TRW or Genuine BMW. Both include a new headlight adjustment rod. Order your kit of choice, with or without hardware.
Fitment:
BMW E82 (2008+)
BMW E88 (2008+)
BMW E90 (2006-2012)
BMW E91 (2006-2012)
BMW E92 (2006-2012)
BMW E93 (2006-2012)
Click HERE to order today!!!!!!!!!!!!!!!
Jul 29, 2019 11:13 AM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
