Agency Power 981 Cayman/Boxster 2012+ Full exhaust systems
These are now instock and ready to ship!!!!!
Agency Power has become well known for their high quality exhaust systems. The Porsche 981 Boxster was released in the summer of 2012 with a total redesign from the previous 987 chassis design. The direct fuel injection Porsche which is available in either the 2.7L or 3.4L engine, lacks the sports car grunt. To meet regulations and sound restrictions, the factory exhaust does rob alittle power and performance which can easily be uncorked. The new Agency Power exhaust system for the Porsche 981 is a complete header back kit. It features secondary cat bypass pipes and a dual muffler with a large dual tip. With an all stainless steel construction featuring exquisite TIG welding and polished piping, the exhaust system including mounting bracket is a direct replacement for the OEM unit.
As tested on our Mustang all wheel drive dyno, the muffler in comparison to stock added a peak of 7whp and 11ft/lbs of torque over stock. Because of the sensitivity of the traction control, the car must be tested in AWD mode which typically yields lower numbers then a RWD test only. However the most impressive gains were between 2500 and 4300 rpm's which are typical driving conditions to get you from 0-60 much quicker.
The exhaust has a more aggressive tone then stock but is still very comfortable for daily use. It is designed to fit the 2012 and up Porsche 981 Boxster and Cayman. It will fit both the S and non S versions. No cutting or welding required.
The all stainless steel headers feature precision TIG welding with a beautiful merge collector. The headers feature high flow catalytic converters. Because of the increased exhaust flow, these headers can trigger a check engine light. We recommend aftermarket ECU tuning to get rid of this CEL if it appears.
6 Speed special pricing:
Headers - $1,795
Exhaust - $1,165
Purchase together and receive a 5% discount!!!!!
480.966.3040
X230
josh@vividracing.com
Headers - $1,795
Exhaust - $1,165
480.966.3040
X230
Armytrix_F1_Exhaust
Jul 7, 2019 11:31 PM
drinaldis
Sep 28, 2015 01:37 PM
Fabspeed Motorsport
Audi
Aug 21, 2015 11:30 AM
