:: ECS Tuning :: Breathe Deeper & Longer With Pipercross !!
Old Apr 19, 2013 | 12:44 PM
ECS Tuning - Porsche's Avatar
Designed as an original equipment replacement, a Pipercross panel filter replaces the factory air filter within the airbox. Installation is as simple as opening the airbox, discarding the old filter and replacing it with a free-flowing Pipercross air filter.
Why foam?
Airborn dirt particles quickly clog conventional paper or cotton-gauze style filters, resulting in a pressure drop that robs the engine of air flow and power. Thanks to deep foam construction, Pipercross filters offer a drastically higher dirt-carrying capacity, allowing air to flow at high rates even after many miles of use - a claim that conventional filters cannot make.
Pipercross filters for this application use a combination of a specially-designed two stage foam, plus a light oil to achieve high performance while still maintaining excellent filtration efficiency.
A Pipercross filter is the last filter you will ever need:
~ Improved air flow - Increased power and torque
~ Long service life - 2-3x the dirt capacity of other filters
~ Efficient filtration - 99.06% efficient to 5 microns
~ Rechargeable - Wash and reuse
~ Lifetime warranty - Peace of mind for life
Add a Pipercross filter cleaning kit and you have a filter that will provide high performance, efficient filtration for years to come.
Click Here to Select Your Vehicle > By Brand > Pipercross
Old Apr 23, 2013 | 02:44 PM
More air flow means more power! Direct replacement with long service life. Order yours Today
Old May 8, 2013 | 01:43 PM
Keep your Pipercross air filter in peak condition with a filter service kit. Each kit includes 75ml of Dirt Retention Additive and 75ml Cleaner, all you need to service your filter.
Old May 23, 2013 | 02:42 PM
Pipercross' Dirt Retention Additive is available in a heavy duty off-road formula - perfect for vehicles in dirty environments or that see off road use.
The superior foam construction of Pipercross filters allows them to hold more dirt and remain efficient for two to three times longer than conventional paper or cotton gauze filters. This dirt retention additive allows filters to regain their superior filtration efficiency after proper cleaning has been performed.
Old Jul 9, 2013 | 01:37 PM
Get rid of your old dirty air filter, that needs to be changed anyway and replace it with a Pipercross Performance Filter TODAY !!
ECS Tuning - VW
Aug 25, 2015 02:54 PM
ECS Tuning - VW
Aug 24, 2015 01:51 PM
ECS Tuning - MB
Aug 21, 2015 02:25 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
