Shifting Issues? May Be Time To Replace The Transmission Mounts! by Pelican Parts
Old Jun 14, 2013 | 11:05 AM
PelicanParts.com's Avatar
PelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond reputePelicanParts.com has a reputation beyond repute
Old, worn out motor and transmission mounts can cause shifting problems because the drivetrain is no longer firmly held in its position. A visible sign that the transmission mounts need replacing is the appearance of cracks in the rubber of the mounts. The rubber will deteriorate over the years and need to be replaced, even if the car has relatively few miles on it. These mounts are also hydraulic, so if you see fluid leaking out of them, then that is also a sure fire way to know that they have failed.
The transmission mounts are fairly easy to replace. Replace them one at a time (remove and replace on one side and then remove and replace on the other side).
For Boxsters through '04 with manual transmissions, we offer a wide range of mount options:
Boxster Manual Transmission Mounts
If you'd like to walk through the instructions for installing, click HERE
Let us know what questions you have.
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Parts | DIY Help | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
gulf gt
Aug 27, 2015 10:27 AM
Fuzzo
Cayenne 955/957
Aug 26, 2015 09:45 AM
MAcarbon
Aug 19, 2015 04:52 PM
ECS Tuning - BMW
Aug 19, 2015 09:29 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
