How do you open the lid?
Old Oct 5, 2007 | 01:08 AM
squid's Avatar
squid is infamous around these parts
Probably a stupid question but how do you open the cover to see the engine? I did a search but didn't come up with anything.
Old Oct 5, 2007 | 01:48 AM
Bruinbro's Avatar
Bruinbro is a jewel in the roughBruinbro is a jewel in the roughBruinbro is a jewel in the rough
I'm assuming you have a Boxster. If it's a Cayman someone else can answer.
Open the soft top about 4 or 5 inches and reach under the rear of the top on any side. You will find a cable that connects the top structure to the top mechanism. The end fitting is a ball and socket joint, just pull the socket off of the ball with an upward twisting motion (kinda like popping the top off of a bottle). Repeat for the other side. Now lift the rear of the top so that it folds up as much as possible. On top of the engine lid there will be carpeting held down with 4 large plastic 1/4 turn fasteners. Turn them 1/4 turn and remove the carpeting. THe engine lid will now be exposed and you can remove it by twisting the 6 (I think) 1/4 turn fasteners. Viola`, behold the engine in all it's glory!
Bro
Old Oct 5, 2007 | 09:10 PM
squid's Avatar
its a cayman
Old Oct 6, 2007 | 10:20 AM
RichP's Avatar
RichP is infamous around these parts
Originally Posted by squid
its a cayman
There is a good writeup on caymanclub; basically, you pull up the rear carpet over the motor, remove the foam insulation panel, then there are 6? torx bolts that are removed to take off the metal engine cover.
Old Oct 6, 2007 | 08:13 PM
sapple89's Avatar
sapple89 is infamous around these parts
jaehoppa
Oct 22, 2015 09:17 PM
ELMEL
Sep 28, 2015 01:12 PM
ECS Tuning - VW
Sep 8, 2015 12:54 PM
Saint Ari
Sep 7, 2015 07:09 PM
