Convertible top slow.
Old Jun 13, 2008 | 05:06 PM
gaby's Avatar
gaby is infamous around these parts
Today I was going to open the top but it did not open. The dash light were dimming every time I hit the switch. After work I try again and it slowly worked but not enough to turn the dash light off. Then I try to close the top and I had to helped it to shut fully. Do you guys think is lack off lubrication, a bad Relay or my convertible top motor is dying?
Old Jun 13, 2008 | 06:51 PM
wingnut2u's Avatar
wingnut2u has a spectacular aura aboutwingnut2u has a spectacular aura about
If the lights were dimming it may just be a weak battery. I would have the battery tested. If that is all it is then you are lucky because that is the cheapest and easiest fix.
Old Jun 14, 2008 | 01:07 AM
Bruinbro's Avatar
Bruinbro is a jewel in the roughBruinbro is a jewel in the roughBruinbro is a jewel in the rough
Do you have the same problem whether the engine is running or not? If so, then check the slides for debris or a broken guide
Bro
Old Jun 14, 2008 | 11:46 AM
gaby's Avatar
Yea it does it with th engine running too. I ll check the guides.
Old Jun 14, 2008 | 03:46 PM
gaby's Avatar
Could not check the guides it won't open now.
Old Jun 19, 2008 | 08:53 PM
wingnut2u's Avatar
Is the top working now? Were you able to figure out what was causing the problem?
Old Jun 20, 2008 | 12:32 PM
gaby's Avatar
No, I took it to the dealer because they gave me a 30 day warranty. But last time I try to open it it will only open an inch and then sounded like (tic tic maybe relay ). I ll post what was the problem once I hear from the dealer.
Old Jul 11, 2008 | 08:42 AM
gaby's Avatar
The problem is the passenger side transmission. The gearing is broke in half.Can I buy the gearing without buying the transmission?
Old Jul 11, 2008 | 03:38 PM
Trent's Avatar
Trent is infamous around these parts
I thought you had a 30 day warranty?
Old Jul 12, 2008 | 12:06 PM
gaby's Avatar
Yes, it is under warranty I just want to help them find the part quick. Is been there for 2+ weeks.
Old Sep 4, 2008 | 11:59 PM
gaby's Avatar
Fixed got both transmissions new under warranty.
cdrik915
New Member Introductions
May 14, 2019 11:15 AM
simoncpw
Sep 8, 2015 10:55 PM
ECS Tuning - BMW
Sep 4, 2015 01:23 PM
zuman
Sep 3, 2015 08:27 AM
AdPock
Ferrari
Sep 1, 2015 10:13 PM
