Heated Seat problems on 2006 Cayman S
SubscribeDoes anyone know where the fuses for the heated seats are? They don`t seem to be with the other fuses in the main fuse box. The reason I am looking is that the heated seats are not working at all, on both sides. No lights come on etc. Could this be a setup problem with the on board computer system? The garage door opener does not work either
No red light when you press any one of the 3 buttons. Resetting it does not make any differance. Can anyone help re these two problems please?
No red light when you press any one of the 3 buttons. Resetting it does not make any differance. Can anyone help re these two problems please?There can also be a coding problem in the control modules. You should have your dealer check with the PIWIS to make sure the feature is activated.
So what was the fix? I'm having the same problem on my 06 C2S. Everything worked fine, then the battery went dead and no home link or seat heaters.
A "vehicle handover" with the piwis tester at the dealership should bring back your heated seats and homelink.
