When to replace clutch? brakes? tires?
Old Apr 14, 2009 | 10:46 AM
jhp012's Avatar
jhp012 is infamous around these parts
I recently leased a 2006 Boxster S with 10k miles on it. Now I have roughly 12k miles on it.
How long does the clutch, brakes and tires last on this car?
The tires look like it is stock tires and has a decent amount of tread left on it.
of course, no one knows the exact answer but can someone give me some ideas for normal driving conditions?
Old Apr 14, 2009 | 01:30 PM
thnxbabe's Avatar
thnxbabe has a spectacular aura aboutthnxbabe has a spectacular aura about
Your tires will have wear bars built into the tread. When the tread reaches the wear bar, you are about a week late changing your tires. Your rears will need it before the fronts and typically you will use 2 sets of rears for each set of fronts.
You can see the break pads inside the caliper. Change when when the "meat" looks thin, or when the break wear indicator light comes on.
Clutch???? You'll know. If you don't ride your clutch, keep it pushed in while waiting at lights, or do boy racer clutch dumps, I wouldn't worry about the clutch.
Old Apr 14, 2009 | 01:34 PM
Max993's Avatar
Max993 is infamous around these parts
I have a 2005 boxster s also the first wheel change in the 33,000 km and the clutch as i change to 39,000 km.
Old Apr 14, 2009 | 06:44 PM
Psypher's Avatar
Psypher is infamous around these parts
If you "Leased" the vehicle, you shouldnt have to change any of them before the lease is up. (except maybe rear tires) With that said, if you do have to replace some or all of the said items, (Minus maybe rear tires like i said) your driving your car too hard.
My .02 cents...
Old May 6, 2009 | 12:32 PM
Seano's Avatar
Seano is infamous around these parts
I get about 15k mi out of Michelin PS2 tires on my '02 S - clutch is fine at 45k mi and I think I've replaced pads once and didn't need rotors yet.
COBB Tuning
Jan 1, 2025 09:02 AM
cerbomark
Aug 22, 2015 12:50 PM
TrackOne
Aug 20, 2015 12:56 PM
Vrseis
Aug 20, 2015 07:41 AM
