'04 Boxster Stereo Help
Old Mar 26, 2010 | 07:00 AM
1SUMBCH's Avatar
1SUMBCH is infamous around these parts
My factory non-Bose stereo is OOC in my '04 Boxster. I've taken it to the local "high end" stereo shop and they're reluctant to install a new stereo - says that the system is priority and installing a non-factory stereo is going to create a lot of problems, i.e. throwing trouble codes.
I've searched the net and it appears that this should be a simple install, though most of the information I've found is too technical for me.
Anyone able to put in simple terms that this is doable, any tricks that we would need to know, and/or any shops near Palmdale/Valencia, CA that could be recommended for a new install?
Thanks in advance.
Old Mar 26, 2010 | 06:21 PM
1SUMBCH's Avatar
Never mind - got the answer.
Old Mar 27, 2010 | 04:20 PM
Dave's Avatar
Dave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to beholdDave is a splendid one to behold
Ummm.....what was the answer?
Dave
Old Mar 27, 2010 | 05:32 PM
Alan C.'s Avatar
Alan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond reputeAlan C. has a reputation beyond repute
I'd think an aftermarket wouldn't be too difficult without Bose. What did you find out?
Old Mar 27, 2010 | 05:41 PM
1SUMBCH's Avatar
Called an installer a little further away and he said it was a simple installation - does it all the time. Says worse case, they might have to bypass the amp.
I'm confused what was the concern from the first well established guy though. I'll get one installed in two weeks and see.
Old Mar 27, 2010 | 06:06 PM
Alan C.'s Avatar
Let us know what you end up with.
Old Apr 9, 2010 | 02:03 PM
1SUMBCH's Avatar
Just had this installed - http://www.alpine-usa.com/product/view/cde-103bt/ The installer said that they did have to bypass the amp, but the head unit's built in amp would be comparable. The stock unit sounded poor, this does sound better. The Bluetooth and front accessible USB ports were musts.
There are videos all over the net right now of the first installer to install an IPad into a vehicle - that's the place that I ended up using. Relatively quick and cost $420 - better than replacing with a factory unit.
jabed92694
Apr 3, 2016 11:31 AM
DannyK
Ferrari
Nov 27, 2015 05:56 PM
