GT3 or H&R Front Sway Bar
Old Jan 3, 2011 | 01:53 PM
chaud's Avatar
chaud is infamous around these parts
Originally Posted by Casey@TPCRacing
What you are looking for cant be described in %'s and rates. The question is what works.
The reason why our bars are more expensive than other companies are because we bend our bars in very small quantities and because we buy a car, take it to a circuit and try multiple rates with different suspension set ups to figure out which ones are the best. The buy that designs them also happens to be a pro driver and knows what works along with different alignment and spring rate changes to get the most out of the car. This is why we sell our suspension systems in packages. You can piece it together but ultimately we know what works the best.
Buying the "stiffest" bar isnt the answer. Buying the bar that is made correctly(hollow, like the factory), bent correctly, made of the best materials and puts down the fastest lap times is the best option. That is our setup. That is the reason that pros use our bars and two race series both use them.
Thanks for the response Casey. I understand that the most stiff is not synonymous with being the best. From what I understand, the GT3 bar is hollow and well made as well. What I'd still like to hear from you or Mike L., is some sort of direct comparison between another commonly used setup, with the 996 GT3 front bar and Tarett rear bar, for example in the boxsterspec series... versus the TPC front/rear setup as you said used in the other race series for the cayman, etc...
Do you have any direct experience comparing the GT3/Tarett setup with the TPC setup? Since you said the % numbers and rates don't accurately describe the differences, can you give us boxster/cayman drivers some sort of comparison breakdown of what driving/racing with a GT3/Tarett setup verus a TPC setup with all else equal would be like? How would you qualitatively describe the handling difference? Are you getting faster lap times, and if so, by how much? I, and I'm sure some of the other guys here, would like to hear what your track findings were in terms of improvement and how you came to the conclusion that these are better, and why they are the best...
Thanks in advance!
Old Jan 3, 2011 | 06:38 PM
ChrisBo's Avatar
ChrisBo is infamous around these parts
Originally Posted by langley996
Get a new shop. That recommendation smells of a shop that has a catalogue on the front desk that thinks they know how much you can spend. You will drop $$$ and leave with a car that does not perform better than before you dropped it off.
Cheers
That's exactly why I joined this forum and made the post ... I recieved my information from the tuning dept of the local Porsche dealership ... they only offer a limited amount of brands and I found it very odd that they were pushing the H&R option over the GT3 set up (after a follow up call the rep told me they do not offer any type of drop link hence the H&R option).
Idealy I would like to have Porsche install these parts although, it seems like this option will limit my options.
If I can find a local shop or mechanic to install the parts I will order everything on line.
On the plus side I'm enjoying reading and researching these options.
Old Jan 7, 2011 | 01:19 PM
chaud's Avatar
Casey?
Old Jan 8, 2011 | 11:51 AM
ChrisBo's Avatar
I'm going to take peoples advise on this forum and my mechanic and purchase tires 1st, sway bars 2nd (GT3 or TPC, I have ruled out H&R).
Is anyone out their using the Sport cup's? There are some good sales on these tires during the winter season that I can take advantage of.
Any thoughts would be greatly appreciated.
Jul 29, 2019 11:13 AM
brockster
Jan 22, 2016 12:18 AM
TrackOne
Aug 20, 2015 12:56 PM
