Introducing the AWE Tuning Porsche Spec Boxster Bolt-On Exhaust System
SubscribeAll of the power with none of the guess work. Engineered and built in-house.
Tested on the dyno. Proven on the track.
Designed with durability, flexibility, power gains and weight loss as top priorities, this System is the only exhaust your Spec Boxster will ever need.
System Highlights:
• Race tested
• Compatible with all 1997-99 Boxster 2.5L
• Bolt On simplicity
• Crafted from mandrel bent 2.25” T-304 Stainless Steel
• Max gains: +36 hp and +29 ft lb at the crank at 6250 rpm
• Peak gains: +11 hp and +1 ft lb at the crank
• 21 lb weight savings with straight pipes (15lbs total)
• 12 lb weight savings with resonators (24lbs total)
• Simple muffler and straight pipe swaps with stainless V-Band Connections
• Porsche OE Style Floating Hanger Design to eliminate cracking under rigors of track use
• Optional Resonators and Turndowns for sound limit compliance
More information and dyno charts are available in the Spec Boxster Exhaust of our website.
Let me know if you have any questions.
System Highlights:
• Race tested
