plus sizing spyder rear tires ?
Old Jun 1, 2011 | 09:32 AM
MR2FAST's Avatar
MR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to behold
Does anyone know if I'll have problems plus sizing the Spyder rear tires from 265 to 275? I'm currently on Bridgestones but really miss the stickiness of PS2s. For some reason PS2s are $100 more per tire in a 265 than a 275 and they dont make the new Pilot Super Sports in a 265... I know the rear wheels are wide enough to take a 275 but will I have issues with rubbing and/or change in outter diameter?
Old Jun 1, 2011 | 02:50 PM
CampioniShop1's Avatar
CampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the rough
You will be fine
PSM might be a bit more sensitive since the sidewall ratio will be higher.
Old Jun 1, 2011 | 06:40 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
Mr2fast
I am Running 295's on the rear of my 2007 Cayman no problems so 275 should be no problem as Championishop stated..
Old Jun 2, 2011 | 09:19 AM
saeyedoc's Avatar
saeyedoc is infamous around these partssaeyedoc is infamous around these parts
I've seen threads elsewhere that suggest oversizing the fronts to 245's if you are going to oversize the rears to 275's. Something about keeping the ratios the same.
Old Jun 2, 2011 | 11:09 AM
MR2FAST's Avatar
hehe I was just going to ask about that. I've noticed a bit of understeer already and wouldn't want to exaggerate it any further.
Old Jun 2, 2011 | 11:44 AM
Fluid987's Avatar
Mr2fast
Deffinately do what saeyedoc said 245 ,s in the front ,If you make the rears wider . When I first put my 295 on the rear it handled horribly until I went with the 245 on the front .
Old Jun 2, 2011 | 02:20 PM
infantrytroop22's Avatar
infantrytroop22 is infamous around these parts
Running 245s in the front with 275s in rear is standard. That's what all the E46 M3 guys run.
AJUSA.com
997 Vendor Classifieds
Oct 8, 2015 05:50 PM
ModBargains
Audi Vendor Classifieds
Sep 1, 2015 05:26 PM
PelicanParts.com
Aug 20, 2015 02:45 PM
ModBargains
Aug 20, 2015 12:28 PM
PelicanParts.com
Aug 18, 2015 03:51 PM
