Question for those who have upgraded steering wheels...
Old Aug 13, 2011 | 09:57 PM
navanod's Avatar
navanod is infamous around these partsnavanod is infamous around these parts
I had the OE standard wheel and later bought the Alcantara Sport Steering wheel that is on the Cayman R and Carrera GTS. I installed it myself using a couple DIY tutorials. One day some idiot decided to run a red light and I slam on the horn. Well the horn was stuck! It would not shut off and I had to immediately pull over and turn the ignition off and push the airbag release on the bottom of the wheel. Later I decided to remove the airbag and inspect. Everything look right and it still sticks. I decided to try the old wheel and it lone and behold it works just fine. So my question is are the airbags the same between the two wheels? or is there another adapter or different mounting screw for the wheel??? Sun Coast says it's a direct swap, but it's not working like it. Any insight would greatly be appreciated.
Original Wheel is this in Leather:
Cayman R/Carrera GTS Wheel:
Old Aug 15, 2011 | 01:23 PM
vinconist's Avatar
vinconist is infamous around these parts
pretty sure its a issue with fitment, you should compare the two wheels side by side and see how the airbags sit in them
COBB Tuning
Jan 1, 2025 09:02 AM
cnebrask
Oct 3, 2024 08:19 PM
Jul 29, 2019 11:13 AM
The Oss
Aug 24, 2015 08:19 PM
JMon
Aug 21, 2015 08:20 AM
