California Counties that do not Req Smog
Old Nov 1, 2011 | 11:42 AM
mrmuddy's Avatar
mrmuddy is infamous around these parts
Question California Counties that do not Req Smog
Anyone ever thoguth about renting a Cal. PO box . in a county that doesn't require a smog inspection and having the car "regestered " at that address .. So that you skate on the biannual ??
Old Nov 1, 2011 | 01:03 PM
GT3 Chuck's Avatar
Administrator
the DMV has thought about it...
"a physical address in California (not a P.O. Box) is required"
Old Nov 1, 2011 | 02:19 PM
Fluid987's Avatar
Fluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond reputeFluid987 has a reputation beyond repute
mrmuddy
Register it here in WA in Fox Island ..No smog checks EVER!!!
Old Nov 1, 2011 | 08:09 PM
boost951's Avatar
boost951 is infamous around these parts
Which county would that be?
Old Nov 1, 2011 | 08:13 PM
denversteve's Avatar
denversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond reputedenversteve has a reputation beyond repute
Yep. Must be a physical address.
Old Nov 1, 2011 | 10:13 PM
djantlive's Avatar
many UPS stores use physical address instead of PO Box.
It's doable.
Alternative to do get a illegal smog check that passes everytime. It's a couple hundred bucks so you may be saving money that way.
Old Nov 1, 2011 | 10:40 PM
Duane996tt's Avatar
Duane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond reputeDuane996tt has a reputation beyond repute
Most shops will let you slide on the visual inspection but the sniffer is hooked up to a computer in Sacto so they can't fake the results.
Old Nov 1, 2011 | 10:41 PM
Duane996tt's Avatar
Can we all use your address
Old Nov 2, 2011 | 02:00 PM
mrmuddy's Avatar
Ca Smog Info
It's doable.
Alternative to do get a illegal smog check that passes everytime. It's a couple hundred bucks so you may be saving money that way.[/quote]
So .....
Having a HUGE appreciation for the sensitivity sourounding this topic.. By any chance.... . would you be willing ..... off line ( e.g. send me a private e-mail to mrmuddy1@mac.com) to share with me the name of a place where they are more focused on getting your car to pass than having you come back a number of times ..before it would pass Of course . that would be AWESOME !!!!!!!!!!! ( And, I would PROMISE !!!!! not to share this information with ANYBODY else !!! )
THANKS !!!!!!!!!!
Old Nov 2, 2011 | 02:41 PM
tradecraft's Avatar
tradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond reputetradecraft has a reputation beyond repute
OP only has 3 posts...watch out guys.
Old Nov 2, 2011 | 03:27 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Why would you need to do this??? If the car is tuned and running properly it will pass the sniffer test. Heck, I have had well tuned cars without a cat pass the sniffer back in the day. I know the visual inspection can be a pain but to be honest most smog places do not know Porsche well enough to tell what is modified and what isn't. LOL
Old Nov 2, 2011 | 04:12 PM
mrmuddy's Avatar
Thanks David... I know that there is a group of us out there .. that don't want to take the risk of putting some stuff on .. then flunking the visial . even though the car is running "better"..
In part, what set me off on this track were all of the vendors who who say " it will definately pass the sniffer .. however, it will not pass the visual "
I bet you are correct.. probably, with a little work,, you could select a shop that did not look real sophisticated and probably pass.. Again, it's kind of an expensive gamble if you don't..
Old Nov 2, 2011 | 04:42 PM
GT3 Chuck's Avatar
Administrator
btw...I guess my hint that you shouldn't discuss this on a public forum was too subtle for you...just so you know...we have several members here that work for DMV...I'll let you know if they subpoena us for your info
Old Nov 2, 2011 | 04:58 PM
mrmuddy's Avatar
Good to know
Guess this thread is dead now
Thanks everyone for your thoughts
DYL 911
Oct 20, 2025 05:08 PM
SlinginHoss
11
Oct 8, 2025 05:16 PM
Kalvin Chen
Oct 20, 2015 09:18 AM
alpha motoring
Oct 2, 2015 12:04 PM
