max tire width on stock wheels?
Old Feb 28, 2012 | 08:51 PM
Haen's Avatar
Haen has a spectacular aura aboutHaen has a spectacular aura aboutHaen has a spectacular aura about
I have a Boxster Spyder which came with Bridgestone Protenzas but they need to be replaced after my most recent track day. I'm looking to get something more aggressive like Yoko AD08, Nitto NT05 and Hankook Ventus v12. (If you have any tire recommendations, I would love to hear them!) My problem is that I can't find any of these tires that match my stock tire dimensions at 235/25-19 and 265/35-19.
How large of a tire can my wheels accomodate? There seem to be more options with wider tires. Stock Spyder wheels are 8.5" x 19" and 10" x 19".
Old Apr 10, 2012 | 01:42 PM
john rice's Avatar
john rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to beholdjohn rice is a splendid one to behold
Don't laugh. Running same size 19" Rufs on wife's 987S. Had tire issue on one rear and put a pair I had sitting around. I wanted to rethink tires before I spent the big bucks and didn't expect to use them more than a couple of weeks... so why not try?
They fit/work much better than I expected and I have no plans to swap them until we wear them out. Wife is happy...especially that I didn't spend $$$ on tires.
Oh, we have 305/30 PS2s. [!] Only slight bulge out and no clearance issues. It also helps with trying to get late corner power down. I am used to 911/930/etc and didn't realize how much I enjoy sling shotting out of corners until I tried it in the 987S. [Too much wheel spin for my taste.] I never would have thought these would work, but they do. Balance isn't bad either. Some push, but I have no problem pushing the tail out. I will probably go to 285 or so when I replace the set.
GL
JR
Old Apr 10, 2012 | 02:09 PM
Dr. Bill's Avatar
Dr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of lightDr. Bill is a glorious beacon of light
That's one reason I got 18" wheels for mine - NT01's will fit. And 18" rubber costs less than 19" rubber.
The main concern is the overall tire diameter. You don't want to vary too much from the stock diameter ratios or you may have ABS issues.
Old Apr 10, 2012 | 05:09 PM
damon@tirerack's Avatar
Moderator
245/295 would be the widest I would be comfortable with recommending. Or, a wider-than-average 235/275 combo like AD08's.
305 is not recommended by Michelin for a 10" factory wheel.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Apr 13, 2012 | 05:47 AM
mphgsp's Avatar
mphgsp is infamous around these parts
I will be getting my first Cayman S very soon. The car I'm getting has 18" wheels so what would the widest tire combination be for 18" wheels? Same as the 19"?
Old Apr 13, 2012 | 10:53 AM
CampioniShop1's Avatar
CampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the roughCampioniShop1 is a jewel in the rough
The Cayman S has 18x8F and 18x9R. You are limited to a 235F and 265R at max width. Anything above will budget and sidewall will have too much flex.
RE: Spyder wheels
19x8.5F and 19x10R is the usual aftermarket fitment on which we run 245F and 275R - you have a lot of options in these sizes.
COBB Tuning
Jan 1, 2025 09:02 AM
Enemy
Nov 10, 2015 08:01 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ModBargains
Aug 20, 2015 12:28 PM
oddjob142
Aug 19, 2015 12:27 PM
