Wheel Nut Torque for Cayman R
I'm getting the Cayman R ready for the track again, and want to make sure the wheel nut torque is correct. The owner's manual seems to indicate 118 ft-lb. Does that sound right? I though about 90 to 100 is more typical, so that sounds a bit high?
- Silver wheel bolts (up to model year 2011) = 130 Nm (96 ftlb.). 160 Nm (118 ftlb.) also permitted retroactively.
- Silver wheel bolts as of model year 2012 = 160 Nm (118 ftlb.).
- Black wheel bolts = 160 Nm (118 ftlb.)
96 ft. lbs. both axles.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
damon@tirerack.com
Or use this link:
This is the correct value for lug bolts if that is what you are looking for. Or lug nuts if converted to studs. Not sure what a 'wheel nut' is.
Seeing that you have a 2012 CR, please recheck the manual. I'm pretty sure the torque spec is 118 ft-lb.
2lflat4
Nov 18, 2019 05:05 PM
Sep 1, 2015 03:16 PM
Aug 20, 2015 12:17 PM
PelicanParts.com
Aug 18, 2015 03:49 PM
