Service cost, am I missing something?
Old Feb 21, 2013 | 09:42 AM
ECS Tuning - Porsche's Avatar
Now I just have to figure out how to reset the service reminder after I do everything.
Thank you again, you'll need a Durametric or a PIWIS to reset the service reminder. Hopefully you know someone with one or you could possibly rent one.
With a build date of 11/2005 I doubt the IMSB is retrofitable so rather than go the expense of removing the trans to verify just get the IMSB Guardian to monitor metal particles in the oil.
As for the IMSB retrofit, LN Engineering will probably have the best idea of what's updated and what's not. PET doesn't say, because you can't buy the bearing by itself from Porsche.
Old Mar 8, 2013 | 05:43 PM
jfondren3's Avatar
jfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to beholdjfondren3 is a splendid one to behold
Originally Posted by mrzy07m
Let me know how doing the service yourself turns out. I have 61,000 miles on my 986S and have been holding off on the service because I only drive the car 300-400 miles per year now.
So today I finally had all the parts I needed and the time so I did the major service on my wife's car minus changing the brake fluid. It took maybe 3 hours max with me and a buddy and a lot of talking. We weren't in any hurry at all. I have actually been surprised at how easily this car really is to work on so far. Tomorrow I'm doing the minor service on my Cayenne S along with brakes.
Old Apr 20, 2013 | 06:59 AM
comtntop's Avatar
comtntop is infamous around these parts
Originally Posted by PNug
This is why I do my own oil changes. Also, if you are outside your warrantees why would you take it to the dealer? Their shop hours are generally much higher than a specialty shop. On the Boxster, I'd have the IMS replaced with L&N's version. You're getting in that range where you could have a problem. A lot of dealers not just Porsche use maintenance services to increase their profit margins. Visual inspection is pretty vague and they can really tack on shop hours that are not really needed. I've seen rates vary more than double from dealer to dealer. Oil changes are expensive on Porsches just due to the amount of synthetic oil, it cost me $65-$80 in materials to do it myself. With my new FVD oil pan kit add another $7 to that but it gets me out of the house and I enjoy working on my cars.
I'm in the process of deciding what to do about the 987.1 oil starvation problem, and one of the 'fixes' I'm looking at is the FVD sump. any comments about your experience with this mod? do you track your car? did you make any other oiling mods?
tks
dave boulder,co
Old Apr 21, 2013 | 10:15 PM
tuner1984's Avatar
tuner1984 is infamous around these parts
tks
dave boulder,co
As long as your not tracking your car from doing research you shouldn't have any oil starvation issues.
Old Apr 22, 2013 | 11:34 AM
PNug's Avatar
PNug is infamous around these parts
tks
dave boulder,co
I haven't tracked my car as of yet. I've not done the installation of the FVD sump; I'm waiting on a pair 996 swirl pots (996-107-080-54) to replace the Cayman's simplified versions of the oil returns. Suncoast can hook you up with the sump and the pots. I wouldn't track my car until you do this modification at the least. There are plenty of guys tracking unmodified Caymans that have had no problems with 1st gen Caymans but some have. If you start upgrading the handling, you're increasing the G's and your risk of a problem. This would be the first modification I'd do before any handling changes just not worth the risk. P-9 has plenty of info on this subject.
Old Apr 22, 2013 | 05:36 PM
comtntop's Avatar
thanks for the reply. I have read everything (everything that I could find anyway) about the AOS and oil starvation problems on P-9. fwiw, I have decided to go with the MS AOS and the FVD sump. still having dialogue with my porsche tech about the TTP oil saver. I will have to make a decision on the TTP kit by mid week this week with a two day track course looming on my horizon.
I have been debating with myself ( third sign of insanity isn't it, arguing with yourself?) about whether to go the oil scavenger route or not. my skill level is probably not high enough (yet) to warrant the pump, but the probability of using some R compound or better tires is pretty high.
if there is some way to quantify (or just SWAG) the incremental risk of a starvation problem as modifications like R's or slicks, or increasing skill levels, etc put the car's capabilities in a place where bad things likely happen.... well, I haven't heard it.
cheers
dave
boulder,co
Old Apr 23, 2013 | 09:01 AM
the_vetman's Avatar
the_vetman has a spectacular aura aboutthe_vetman has a spectacular aura about
If you're concerned about oil starvation in Gen 1 cars - and you should be if you're going fast enough - the most effective solution IMO is to go with an Accusump (vs. oil pan, TTp, etc.). Solves the root of the problem of instantaneous drop in oil pressure. Well, it doesn't actually solve the root of the problem but it's the most effective way of dealing with it.
It's been used with great success in racecars for decades (including Spec Boxsters). You can buy it fairly cheaply either used or brand new on eBay (original Canton Racing Accusumps). Much cheaper than TTp and similar price to some of the more expensive deep sumps.
Serg124
Sep 10, 2015 05:27 AM
gulf gt
Aug 27, 2015 10:27 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
