PSM audio alert on track
Old Oct 4, 2013 | 08:37 AM
Christian Frank's Avatar
Christian Frank is infamous around these parts
I took my 2010 Cayman S chrono to Grattan Raceway for the first time yesterday and was amazed by the performance, with one exception: I started to hear the same chime that sounds when you turn off or on the PSM traction control system. I couldn't pin it down to a single driving condition. It would do it sometimes under breaking in tight corners, other times under heavy acceleration through corners with hill tops that would de-weight the car. I'm use to seeing the PSM yellow light on the dash showing active handling corrections, but what is with the random chime? As the tires got hot and increased the pressure to 33 to 36, it happened more and more. It repeated the noise in both regular and sport mode. Can somebody explain what is happening? Is the car telling me it's at the limits of PSM? No messages, or warning lights stayed on. Has anybody else experienced this chime?
Old Oct 4, 2013 | 09:36 AM
MR2FAST's Avatar
MR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to beholdMR2FAST is a splendid one to behold
did you turn PSM off? If not, you should
Feelgood MD
Mar 24, 2016 09:35 AM
bzimpfer
Sep 26, 2015 10:55 PM
Korntera
Sep 15, 2015 08:20 PM
WheelB
991 Turbo Vendor Classifieds
Sep 3, 2015 10:26 AM
