Windshield Fogging Due to Air
I live in Miami, FL. When running the air conditioner, part of the air flow escapes through the defrost exits on the dashboard. So when it's humid outside, this problem causes the front windshield to fog up. If I put on the wipers, it clears the issue temporarily but spreads the humidity on the windshield. So, the problem gets worse when the wipers are turned off. Has anyone encountered this problem. If so, what is the solution other than my mechanic taking apart the dash to fix the issue.
Experiment with the buttons until you find settings that allow air to flow from the center and floor vent and less -- ideally none at all -- to the vents at the base of the windshield.
Maybe in your case the A/C temp control needs to be adjusted a bit warmer?
A bit of a long shot but just to be safe be sure the water drains on either side of the battery are free of trash and there is nothing there to hold dampness or worse allow water to collect. If there is any dampness this could possibly exacerbate the tendency for moisture to condense at the base of the windshield.
