Frunky fog lights
Subscribe
Aug 27, 2018 | 07:38 PM
Hi all,
I've got an '06 Cayman project that I've been working on that i'm having an issue with the front control module that I have not been able to resolve. Both the front fog lights and the frunk compartment light will not illuminate. I'm able to see the associated inputs go active in Durametric, and i'm also able to activate the output lines and the lamps illuminate as expected. No fault codes are indicated either. I've read a few threads online from others with a similar problem, who have been able to resolve this by 'resetting' the module. I've tried changing the coding, and doing a backup/restore in an effort to 'reset' the module, but to no avail. I've had the battery disconnected several times, so it doesn't seem that a power cycle will reset the module either.
I'd appreciate any suggestions on how to reset the module, perhaps via the command line in Durametric?
TIA
-kk
Reply
Subscribe
