NorCal Durametric
Old Apr 30, 2023 | 08:23 PM
EJ_Rapide's Avatar
EJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond reputeEJ_Rapide has a reputation beyond repute
NorCal Durametric
Hello guys,
Anybody has a Durametric in the North SF Bay Area?
I have a PSM failure message I can't get rid of, so I'd like to read the codes to point the actual culprit.
TIA!
Old May 1, 2023 | 06:00 AM
MikeSpillerr's Avatar
MikeSpillerr is infamous around these parts
If you don't have a Durametric, there are a couple of things you can try before resorting to spending the dough on one.
First, you can try disconnecting the battery for about 10-15 minutes to reset the computer. This might clear the error code and let you start fresh. Just make sure you have any radio codes or security settings handy, 'cause they might reset too.
If that doesn't work, you could try getting an OBD-II scanner from your local auto parts store. They're not as fancy as a Durametric, but they can still read basic error codes and give you a general idea of what's going on under the hood. And they're usually pretty cheap to rent or borrow.
Mkhan
Southwest
Nov 5, 2015 10:42 AM
rangerdick
Nov 29, 2012 07:13 PM
