Boxster Wiggle
Old May 18, 2023 | 05:34 AM
Pastor T's Avatar
Pastor T is infamous around these parts
Boxster Wiggle
Ok guys, here is one for you guys. My 2000 Boxster 2.7, 185,000 miles, has a tracking issue in the rear. When going down the road in a straight line 50 mph and above, the rear end darts back-and-forth almost like you were driving on some kind of grooved pavement.  it’s not like the car is fishtailing, it’s just a wiggle.  i’ve had the car up on Jack’s and been all over underneath. I see nothing loose or out of place. I’ve pushed and pulled and tugged on everything. I’ve checked every nut and bolt on all of the suspension sway bars, etc., nothing loose. Wheel bearings are good, shock mounts are good. I’ve had it on jackstands with the rear tires hanging free i.e. no weight. I’ve had it on jackstands and then jacked up each tire so that it is holding weight and checked it for anything loose.  I changed my tires, Michelin pilot sport, and put my sticky track tires on. It still does the same thing.  the only thing that I can figure is it may be the steering rack. I don’t feel any play in the wheel. I don’t feel any play while driving and the rear end is wiggling. Recently change the front motor mount  so that is good. I have never changed the two transmission mounts. This has got me stumped. I’ve owned the car for 13 years and put 100,000 miles on it. I’ve never seen or felt anything like it. has anybody got any  bona fide ideas. Please, no jokes, I’m way past that. thanks in advance.
Old May 28, 2023 | 09:39 PM
J-Rad's Avatar
J-Rad is infamous around these parts
Have you checked the wheel balance? A rear wheel could be unbalanced or maybe even bent. When did you last check alignment? Have a tech or someone local take it for a test drive as well.
Old Sep 17, 2023 | 10:59 AM
NeilS08's Avatar
NeilS08 is infamous around these parts
Wiggle
I had the same issue with my 2009, when I hada 4 wheel alignment this problem was solved.
Neil
Another P
May 25, 2012 03:07 PM
Bonerwall
May 24, 2012 09:23 PM
02m3smg
Feb 5, 2010 10:43 AM
Crazed1
Oct 20, 2008 02:39 PM
StephenTi
Apr 27, 2007 12:53 PM
