986, 3.4l swap, now check engine light?
Old Dec 18, 2006 | 05:29 PM
turbomx5's Avatar
turbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to beholdturbomx5 is a splendid one to behold
Hello all.
Some of you may know I have a 99 986 that just received a 3.4l swap. It is still using the all the old parts except for the engine itself. (ecu, injectors, headers, exhaust are all from the 99 boxster)
I have been having check engine light issues. The fault code says there is a vaccuum leak at idle. The light takes about 100 miles to come on. We have checked for obvious leaks, and replaced the oil filler neck thinking that was the problem.
Have other cars had this issue? I feel like I have run out of leads to chase. Some are suggesting an ecu reflash, but that doesn't make sense to me.
Anyone else had this issue?
Matt
Old Dec 18, 2006 | 06:05 PM
IAPorscheDoc's Avatar
IAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond reputeIAPorscheDoc has a reputation beyond repute
Did you reflash the ECU to the 3.4L file?
Old Dec 18, 2006 | 06:14 PM
turbomx5's Avatar
no. no reflash was done. I was told this wasn't required at this point?
oddly, I have been told by several people that an aggressive reflash sometimes throws a check engine light because of engine bay temps?
Old Dec 19, 2006 | 10:46 AM
Start with what is obviously wrong, and running a 2.5L program on a 3.4L is a big one.
Old Dec 19, 2006 | 08:34 PM
turbomx5's Avatar
Doc-
I sent you a pm that you can disregard.
I just found out that the 99 cars do not have field reflashable ecus. only the 2000+ ones do. So what are my options? I know a 1999 996 ecu will plug into my harness, but don't know if it would actually run start the car.
Does someone have a new chip for this ecu that has the 996 fuel and timing tables?
tropicatango
Jun 8, 2025 01:00 PM
Mini George
Jul 29, 2019 12:20 PM
Mini George
Jan 18, 2016 09:16 PM
Aug 20, 2015 12:17 PM
