:: ECS Tuning :: Quick Cures For Common Cayenne Concerns
Old Nov 29, 2012 | 12:37 PM
ECS Tuning - Porsche's Avatar
Chasing a mystery coolant leak? If your 2003-2006 Cayenne is losing coolant, odds are you can trace it to the original plastic coolant pipes located beneath the intake manifold. That's why ECS Tuning has assembled the most comprehensive coolant pipe repair kit available in the aftermarket. Our problem solver package includes original equipment cast aluminum coolant pipes, hardware, and seals. We even include a new thermostat gasket, a part commonly excluded from competitors' kits.
For information and to purchase Click here
Your hatch shouldn't be falling on your head while you unload your cargo. This kit includes everything you need to replace your hatch struts.
For more information and to purchase Click Here
The High and Low Pitch Horns commonly go out on Cayenne's replace them with a direct fit replacement.
Replace your standard Base/S/Turbo lower control arms with units from the Turbo S. With thicker, heavier duty bushings, you won't have to deal with torn or loose bushings again, and you will have a more responsive and predictable ride.
Hatch window won't open? A likely cause is a faulty tip switch. This updated switch includes a new wiper arm cap, since yours was probably missing anyway.
If your getting thumping noises or vibration make sure to check your center drive shaft support bearing.
This component is a simple replacement and will rejuvenate your vehicle’s performance and fuel efficiency. If you are replacing any aspect of your ignition system, it's best to replace all serviceable components.
Take a look at your other mounts prior to ordering. Grab your engine by the top and shake it. If it moves rather significantly, replace all the mounts to stiffen up your entire driveline for better performance.
If you have ever got the message that says replace your cornering headlights this is the solution to get that error message off of your screen.
Improve your interior lighting experience, open your door to a world of stunning light from Ziza.
Old Feb 1, 2013 | 02:49 PM
All Cayenne LED
interior lighting kits are now Free Shipping for a limited time only.
Click Here for more information
Old Feb 28, 2013 | 01:19 PM
ECS has made it easier than ever to get the quality replacement matching components you need when beginning a brake service. Our brake service kit includes rotors, pads, sensors, assembly grease, and set screws to make your brake replacement easy. A complete matched kit assembled by our team of experts, will keep all of your brake components working in perfect harmony. These kits include everything you need to service your brakes in an afternoon in one simple kit from ECS Tuning
955
955 Base: Click Here
955 S: Click Here
955 Turbo: Click Here
955 Turbo S: Click Here
957
957 Base: Click Here
957 GTS: Click Here
957 S: Click Here
957 Turbo 08 : Click Here
957 Turbo / S 09 - 10: Click Here
Old May 13, 2013 | 01:30 PM
Don't delay order your brake kit Today !!
Old Dec 16, 2013 | 12:17 PM
All assembled by ECS Tuning Kits are now on Sale until 1/5/2013!! Act now before the sale passes you by.
Click Here to Select Your Vehicle> By Brand > Assembled By ECS
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
