:: ECS Tuning :: 957 Rear Drive Shaft Support Bearing
Old Jun 9, 2014 | 11:11 AM
ECS Tuning - Porsche's Avatar
If you hear or feel a thumping under your center console while turning corners or accelerating, it's likely the center support bearing in your cardan shaft has failed. Inspect the rubber around the bearing for tears, and move the driveshaft to check for excessive play at the bearing.
A damaged bearing should be replaced immediately to prevent further damage. This bearing must be pressed on. Professional installation is recommended.
ID:	384656   Click image for larger version
The_Ruski_Driver
Oct 25, 2015 08:40 PM
ECS Tuning - VW
Aug 20, 2015 02:01 PM
ECS Tuning - VW
Aug 19, 2015 02:36 PM
ECS Tuning - VW
Aug 19, 2015 02:15 PM
ECS Tuning - VW
Aug 19, 2015 01:23 PM
