955 Cayenne Turbo GruppeM Carbon Fiber Cold Air Intake System from GMP Performance
Old Sep 26, 2016 | 11:54 AM
GMP Performance's Avatar
Site Sponsor
The aftermarket world is ever evolving, with each new chassis becoming the hot topic and the market flooding with parts for the newest projects. With three generations of the Cayenne, it's easy for Porsche's maiden voyage into the SUV world to sometimes feel a little neglected. Proud owners of a 955 Cayenne ourselves, we have no intention of letting that happen. It's time to take your "collector's item" and start playing!
That's where GruppeM can step in. GruppeM manufactures high quality cold air intakes that add performance and a powerful style under the hood.
First, performance: Airflow is the key ingredient to the combustion cycle of a high-performance engine. Therefore, the intake system cannot be ignored and must stand up to the task of supplying the engine with not only clean air (free of any residue or particulate matter), but also maintain ample cooling to provide the highest density possible, in addition to properly utilizing the ram effect at high speeds, to effectively increase the volume of the intake charge. These are key ingredients to bring out the full potential of your engine.
GruppeM's exclusive ram-air design cools the intake charge from excess engine heat and forces a higher volume of air into the engine's manifold for more power and a throaty sound. Engineered to increase airflow, increase air velocity, stabilize the flow pattern, decrease intake air temperature, and decrease weight, the GruppeM RAMair™ intake system takes high-performance to a new level.
Now on to something equally important: Style! Who can go wrong with a good dash of beautifully manufactured carbon fiber and with GruppeM, you'll get more than enough to make a potent impact.
Every GruppeM carbon fiber air intake system is made by hand with lightweight carbon fiber composites using the most advanced “wet” and “dry” carbon fiber manufacturing processes. Each design is different to create the best shape for each car model to maximize utilization of the limited available space in the engine room compartment so you're guaranteed a perfect fit for your Turbo.
When installation time comes, rest easy. All GruppeM air intake systems come complete with precise installation kits providing bolt-on simplicity to the fitting process including the exclusive design of the GruppeM fitting adapter to ensure each fitting is exact. The custom K&N filter made for specifically for GruppeM is easily maintained with normal cleaning long performance life. K&N filters are designed to function and perform as new following regular cleaning of the cotton fiber.
To find out more on this part, click here!
amgpan
Jan 18, 2020 12:05 PM
SuperPenguin
Aug 26, 2016 07:46 AM
echerbst
Aug 18, 2016 10:58 AM
j_vincent
Cayenne 958
Aug 16, 2016 12:56 PM
