Headlamp Washers
Old Oct 18, 2007 | 09:37 AM
MLC's Avatar
MLC
Awaiting Email Confirmation
MLC is infamous around these parts
Headlamp Washers
Hello Members
Looking to add washers for headlamps on my CS i have the turbo bumper and the blank plugs.
Does anyone know if adding them is possible/Easy?
Any help is great.
Old Oct 20, 2007 | 10:22 AM
G_A's Avatar
G_A
G_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of lightG_A is a glorious beacon of light
It is possible to add washer. You need all original parts from turbo bumper - covers, nozzles, cylinders, top and bottom mounting support, connectors, screws, also washer pump, pump harness, seal ring and new tank or make hole in original one. Also you need few meters suitable hoses. After all you will need to reprogram Electrical system CU for headlight washer installed. You have to connect control wire to ECU pin according wiring diagram, add new relay, and connect ground and power thru new fuse. We did this once and all works ok in original Porsche manner.
Old Oct 20, 2007 | 07:18 PM
SoCal955's Avatar
SoCal955 is infamous around these parts
I say stick with the blanks.
7thsign
Dec 12, 2015 07:43 PM
WEEED
Cayenne
Sep 25, 2015 10:45 PM
