2005 cs going in for warranty repairs---what should i get checked out
have the following list and additions will be helpful and greatly appreciated
1::slight hesistation while starting to drive--poss coils or something else---
2::ticking noise when steering turned all the way to the left
3:::rear tailgate and glass drop down sometimes----
4:::wipers shuddering
5: clunk under floor when accelearting then braking
6:::coolant dripping under engine
7:::now and again the pcm does not turn on----or no cd catridge detected----
what else should i have looked at as a precaution____any air con issues or suspension issues -------and any tranny issues-----------
he is in desperate need of help
. Lovethesport, I cant really help you out b/c i just recently purchased a cayenne a couple of days ago, so i do not really know to much about the maintanance of the vehicle, but it sounds like you pretty much have everything down, just tell the dealer, or an outside party to do a full inspection of the vehicle. Also if you have air suspension, i would defintly tell them to check the suspension out. As for the pcm not recognizing the cd, it happened to me the other day on my gts, it said that there was no cd or cd changer, and i had a cd in the pcm. all i did was turn the car on and off and it was back to normal. hope this post somewhat helps you out.
2lflat4
Nov 18, 2019 05:05 PM
Apex Chase
Mar 28, 2016 02:00 PM
