TPMS giving false alarm on 08 Cayenne S?
Old Oct 16, 2008 | 06:58 PM
cellg8's Avatar
cellg8 is infamous around these parts
The display showed my tire pressure was low (-4 on back passenger side tire). I went to get gas station and found the pressure was at 38... I pumpped some air anyways to make it 44... It still showed -2 and then back to -4 again.
1) What's the normal tire pressure for Cayenne S?
2) Has this happened to anyone and how do I reset?
Thank you.
Old Oct 17, 2008 | 11:27 AM
Filin's Avatar
Filin is infamous around these parts
try to change TPMS settings - select 19" or 21" and then back to your size.
worked for me
Old Oct 17, 2008 | 12:14 PM
Jace's Avatar
Jace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of lightJace is a glorious beacon of light
happened to me before.
Check your factoy settings on the door, but do what filin mentioned and that should reset.
Did it to mine, and all good now... plus I filled with nitrogen...
now when they fluctuate, it's even all around....
socialpro
Cayenne 958
May 18, 2016 09:58 AM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
