Dependability of the 04-05 Turbo
Old Oct 26, 2008 | 08:18 PM
porschespeeddemon's Avatar
porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !porschespeeddemon Is a GOD !
Originally Posted by Cannoli
I was just going to say this too ... I'm not sure when Porsche switched to the aluminum tubes - it could be with 957 4.8L. What we are talking about are plastic tubes, I believe there are three of them, that run between the heads under the intake manifold, transporting fluid from the rear to the front of the engine. These tubes are part of the engine cooling system. The engineer who specified PLASTIC (ABS or Nylon) to be used next to one of the HOTEST areas of the engine should be fired! What was he or she thinking? The update to this shortcoming is now aluminum tubes. If the plastic tubes spring a leak, the intake manifold must be removed.
My RUF Dakara 550 is based on the 2004 955 Cayenne Turbo and it has been rock-solid electrically and some minor mechanical issues have been dealt with during the warranty period.
I'm VERY pleased with my 2004!
There wasnt a "year" split for the aluminum cooling pipes. It was more of a date of mfr split on the engine numbers which I do not have, however I have replaced a few Cayenne engines, and one new one came with plastics, Porsche wanted the aluminum ones put in prior to engine installation. Since then, all new engines (or reman) come with metal pipes. 957 cayennes use a different system, but have also had a few issues near the T-stat with some minor coolant leaks. Aaron, PM me if you have any questions.
Old Oct 26, 2008 | 11:09 PM
Cannoli's Avatar
Cannoli is infamous around these parts
Good info ... thanks for clarifying.
Old Oct 27, 2008 | 06:19 AM
Also to someone who was asking, there are 4 pipes. One set of 3 about an inch in diameter each, that run on top of the 4th, which is approx 2" in diameter. If one breaks, replace them all, not just the broken one.
Old Oct 27, 2008 | 10:47 PM
mpatrizio's Avatar
mpatrizio is infamous around these parts
Originally Posted by FastForwardwheels
I hear a lot about the 03 & 04 models and lot's of pos+ on the 05 & 06....
But can anyone contest to this who has FIRST-HAND knowledge??? Gant it that the 03-04 have been on the earth 2-3 years longer than the 05-06 so of course there will be more mechanical failures if compared side to side.
I'd prefer the owners step up rather than speaking 2nd hand such as "my neighbor" as times will tell many of those guys over-state their business for attention etc. First hand experience would be the best.
Just my .02, hope to hear honest and down to earth replies....
-Eli
For what it's worth...
I think you're searching for info for this on the wrong site. It seems that most of the "beta" Cayenne owners are on the other message board. But if you listen to some of them, they'll convince you that there's no such thing as a good '03 or '04.
I wander over to that site for more technical answers since those guys seem to have had much more bad luck than this group... Either that or their bad luck group is more outspoken!!
Old Oct 29, 2008 | 03:25 PM
glowone's Avatar
glowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to beholdglowone is a splendid one to behold
04 v 05
Ill keep all this in mind. Thanks for any more input.
Can I see these pipes if I look in the engine?
Old Nov 1, 2008 | 11:11 PM
Wheel Dynamics's Avatar
Wheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond reputeWheel Dynamics has a reputation beyond repute
NOPE....
You can see it here though, they are located just above #5 in the diagram.
-Eli
Old Nov 1, 2008 | 11:15 PM
If that's the case, I don't want to go to that site,,,,, full of bad luck or something....
-Eli
COBB Tuning
Jan 1, 2025 09:02 AM
Jul 29, 2019 11:13 AM
alevine
Nov 4, 2015 10:05 AM
Christian
Aug 24, 2015 12:56 PM
Tremelune
Aug 23, 2015 01:17 PM
