Secondary cat bypass installation tips?
Old Dec 26, 2008 | 04:09 PM
B Feelgood's Avatar
B Feelgood is infamous around these parts
Removing the crossmember and letting the piping drop all the way down is an easy way to get to that top bolt.
Old Dec 26, 2008 | 05:21 PM
the head's Avatar
the head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the roughthe head is a jewel in the rough
Originally Posted by Reborn996
Okay Head, but how does it sound?! I am looking into getting these for my 04 CTT and wondered if it was good enough without doing the mufflers.
Pretty close or just like stock at idle and just driving around as far as I can tell. I had a car full of kids earlier so I didn't get the chance to air it out.
Old Dec 26, 2008 | 05:27 PM
the head's Avatar
I had thought about that but my jack doesn't go that high and I wasn't sure if that much wood stacked up would be a good thing.
Old Dec 26, 2008 | 10:20 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
Sounds like you need to drop off the kids and take that thing for a real drive!
Old Dec 28, 2008 | 03:55 PM
the head's Avatar
Not much of a difference anywhere as far as sound or power. But I wouldn't expect to really feel 10-20hp in a 5600 pound vehicle, either. If it's any louder I'm not sure I can tell. The dragstrip will tell me what it's doing in January.
Old Dec 28, 2008 | 04:40 PM
have2modit's Avatar
have2modit is infamous around these parts
Just installed fabspeed cat bypass on my 05 ctt a week a go and i am loving it. got rid of the lag and now it really comes on strong around 3k rpm. more throaty exhaust , inside and out. and especially on cold start and when you rev it up. i can feel the power increase in the midrange. going to take a video soon
Old Dec 28, 2008 | 08:55 PM
Cpa4S's Avatar
Cpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to beholdCpa4S is a splendid one to behold
there are some other great threads on the sound of the by pass pipes. no one disliked them if i remember correctly.
i am going to do it next year when it warms up? although i do have a service in 1,200 km coming up som maybe i will bug Fabspeed sooner?
Old Apr 9, 2012 | 04:17 PM
garukun's Avatar
garukun is infamous around these parts
I had to revive this thread since the original poster seems to from the NWA region. I'm curious how the installation ended up going? Did you guys find a shop here in Eastside/Seattle that does it for you? How much did it cost you?
I definitely want to install this thing myself as a fun experience, but it's sounding like something I need more courage/time and skill.
Also, how would removing that cross member help, it does not change the positioning of the pipes does it?
Old Apr 9, 2012 | 05:43 PM
crowland's Avatar
crowland is infamous around these parts
No special skills needed, just a little patience- I was trying to dig up my instructions for install but cant seem to find them. You drop that cross member so that you can loosen the rear clamps and then drop the pipes down, then you just loosen the 3 bolts at the primary cats -which is the most time consuming frustrating part of the job. A set of rotating wrenches will come I handy for this- be forewarned though it is a HUGE pain to remove these bolts, especially the top one. My suggestion is to use some penetrating oil and spray the 3 bolts for a few days and let it soak as it might help loosening them.
Only tools needed are a floor jack(I used a scissor jack out of another vehicle) a couple of wrenches and a little patience. I ordered mine from Leistung Motorsports and they actually include the U-joint wrench you need to get at the top bolt that I and other have mentioned.
I will say I could probably do the job 50 percent faster after you've done it once.
Old Apr 10, 2012 | 09:35 AM
03EvoIII's Avatar
03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute03EvoIII has a reputation beyond repute
installing the secondary cat-delete pipes is super easy...
Jun 10, 2017 07:45 PM
Mini George
Jan 18, 2016 09:16 PM
ct-andy
Cayenne 958
Aug 21, 2015 02:08 PM
Aug 20, 2015 12:17 PM
