sprint booster installed
Old May 7, 2009 | 07:42 AM
MTRX's Avatar
MTRX is infamous around these parts
I also would like to know if this works on 2nd gen Cayennes... I have on 08 S and wonder if this is going to make any difference.
Old May 7, 2009 | 07:59 AM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Works on mine and it is an '09
Old May 7, 2009 | 09:19 AM
al7zin_ad's Avatar
al7zin_ad is infamous around these parts
it cancel the warrnty?
Old May 8, 2009 | 07:42 AM
imcarnuts's Avatar
Do not know for sure but it only takes 15 minutes to install yourself so if anything would happen, just remove it. My dealer knows it is on my vehicle as I don't hide anything from them but I have an over thirty year relationship at my dealer.
Old May 8, 2009 | 09:58 AM
roxboxxx's Avatar
roxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant futureroxboxxx has a brilliant future
Wonder if GMP will do a group buy if we get at least 5 to say yes. I myself like driving with PSM off until I get up to highway speeds as the throttle response is night and day.
BUT with PSM off, I always get the sense that I just reduced my chances of survival if I have to make an emergency maneuver. After reading what PSM does, I may be right
"The Cayenne's combination of precise balance and confidence can best be described as "sure-footed." This remarkable poise can be attributed, in part, to the revolutionary Porsche Stability Management (PSM) system. PSM uses a series of sensors as well as information from the Porsche Traction Management System, to monitor direction, speed, yaw velocity and lateral acceleration. PSM then uses the sensor readings to calculate the actual direction of vehicle travel.
The system can reduce understeer caused by sudden steering inputs when changing lanes or negociating a rapid sequence of bends, as well as mitigate understeer encountered when entering a corner at speed, especially in low-grip conditions. If the Cayenne begins to oversteer or understeer, PSM applies selective braking on individual wheels to help keep the Cayenne on the desired cornering line. If braking alone isn't enough to maitain control, PSM then utilizes the engine management system to control engine output in order to stabilize the handling.
PSM also compensates for mid-corner changes in load resulting from deceleration or braking, and when accelerating with the rear wheels on different surfaces, it improves traction and keeps the Cayenne on course. Braking is stable in all types of weather, while braking distances are reduced to a minimum.
A PSM indicator on the instrument cluster displays the systems presence. Of course, PSM can be switched off and is re-activated by braking.
Old May 8, 2009 | 10:46 AM
acasshmoney's Avatar
acasshmoney is infamous around these parts
group buy??? anyone
Old May 8, 2009 | 11:24 AM
roxboxxx's Avatar
i'd give it a go as I think GMP gives a no hassle return option in case I don't like it.
Old May 8, 2009 | 07:42 PM
mrvegas's Avatar
mrvegas is infamous around these parts
I might be up for a group buy!
Old May 8, 2009 | 08:32 PM
roxboxxx's Avatar
I just PM's GMP - lets see what they say. Hopping economy suckage will help with the offer (if there is one to be had).
Old May 8, 2009 | 09:36 PM
MadeInPorshe's Avatar
MadeInPorshe is infamous around these partsMadeInPorshe is infamous around these parts
Sweet, id be in on the group buy aswell!!
Old May 8, 2009 | 09:51 PM
roxboxxx's Avatar
well thats a few maybes and a couple of for sures - so thats ummm 4ish.
Old May 8, 2009 | 11:39 PM
al7zin_ad's Avatar
yes for group buy
Old May 9, 2009 | 12:17 AM
why dont we get a list started and then talk it up with GMP
1-acasshmoney
2-
3-
4-
5-
6-
7-
8-
9-
10-
Old May 9, 2009 | 12:26 AM
roxboxxx's Avatar
LOL - Way to force feed it Cmoney
1- acasshmoney
2- roxboxxx
3-
4-
5-
6-
7-
8-
9-
10-
Old May 9, 2009 | 12:47 AM
haha im jsust tyrign to get good deals for everyone ya know
