Rinspeed Cayenne Turbo
Old May 14, 2009 | 07:23 PM
JackyN's Avatar
JackyN is infamous around these parts
Originally Posted by Kingshawn1234
Thats the sickest cayenne ever!
Did you powder coat your wheels? Where did you get the black center cap from?
Thank you. The wheel is painted in black same color as my car and i made a silver rinspeed sticker for the center cap. Rinspeed don't have black center cap.
Old May 14, 2009 | 07:25 PM
JackyN's Avatar
Hi All
Thank you for all your comment!
Old May 14, 2009 | 07:27 PM
JackyN's Avatar
Originally Posted by gulfviewmassive
That's absolutely stunning! What does kit and wheels run? Those wheels are the best wheels for the cayenne that I have seen, especially in 23s..........315s around!
Hi Thank you. My wheels are 23"X11" with spacer and the tires are 315/25/23.
Old May 14, 2009 | 07:29 PM
Kingshawn1234's Avatar
Kingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud ofKingshawn1234 has much to be proud of
I also had mine painted black... since the tires are such low profile i hear they will crack easily and if there powder coated it gets a bit weaker... Do you drive right over pot wholes and bumps? or are you careful because everyone tell me to be careful with the wheels do u think it really matters?
heres a pic of my wheels
Old May 14, 2009 | 07:39 PM
JackyN's Avatar
Hi Kingshawn1234 nice car! If you power cost the wheels is fine and it won't get weaker. I always slow down if i see any bumps because the tires are too thin and the wheels will crack so you really need to becareful but i think LA got alot nicer road than Hong Kong.
Old May 14, 2009 | 08:06 PM
golo's Avatar
golo is infamous around these parts
very very nice, how much is the rinspeed bodykit and wheels cost in hk?? thanks
Old May 14, 2009 | 08:22 PM
LosAngeles's Avatar
LosAngeles is a glorious beacon of lightLosAngeles is a glorious beacon of lightLosAngeles is a glorious beacon of lightLosAngeles is a glorious beacon of lightLosAngeles is a glorious beacon of light
you said you have lowering links. is that the only thing you have done to lower your car? doesnt the turbo have air suspension thus you cant put lowering links? so is this a true ctt?
anyone feel free to explain.
if you can put lowering links on 08 09 ctt how is the ride with the links?
Old May 14, 2009 | 08:30 PM
OSIKS4's Avatar
OSIKS4 is infamous around these parts
I was very hesitant to click on this thread because this is my dream car right now!!!!!
Old May 14, 2009 | 08:37 PM
JackyN's Avatar
It cost about USD22000 for the bodykit.
Old May 14, 2009 | 08:40 PM
JackyN's Avatar
Originally Posted by LosAngeles
you said you have lowering links. is that the only thing you have done to loser your car? how is the ride with the links?
Yes i only got the lowering links and the ride is acceptable. My car is set to loading level so it'll raise up a bit while driving.Mine is a 08 CTT with air suspension and you can use lowering links to lower your car.
Old May 15, 2009 | 04:13 AM
tuki's Avatar
tuki is infamous around these parts
stunning pepper!
how is the ride quality with those links? And how much it lowers the car?
Old May 15, 2009 | 08:56 AM
JackyN's Avatar
Originally Posted by tuki
stunning pepper!
The ride quality is acceptable. I lower about 35mm because if you go too low the ride quality will be very bad.
Old May 15, 2009 | 09:07 AM
caltex's Avatar
caltex is a name known to allcaltex is a name known to allcaltex is a name known to allcaltex is a name known to allcaltex is a name known to allcaltex is a name known to all
Thumbs up Sick that's all I can say... That is one sick CTT
Well done!
Old May 16, 2009 | 02:57 AM
LosAngeles's Avatar
you use the word "acceptable" does this mean there is a considerable difference in ride from stock height before lowering links?
Old May 16, 2009 | 09:26 AM
JackyN's Avatar
Yes after 35mm lower you'll feel about 35% harder than stock if you drive in normal height mode and 50% harder in lower mode.
