Engine Temp
Old Jun 30, 2009 | 10:34 AM
bcherry's Avatar
bcherry is infamous around these parts
Engine Temp
When you are driving your Cayenne "vigorously" what does your engine temp get up to?
I have an '05 CTT and (assuming the dash gauge is accurate) it gets buried pretty strong in the 220/230 range... right at or just above the line between 180 and 260.
I don't like that the gauge goes from "normal/white" lines immediately to "bad/red" with no gradients. Should I be worried about the space between the last white line (~220) and the bad red line at 260?
Old Jun 30, 2009 | 05:08 PM
canberk's Avatar
canberk is infamous around these parts
my engine temp never goes above 180, no matter what i do with my car, including hardcore offroad situations..
Old Jun 30, 2009 | 08:38 PM
Joeacc's Avatar
Joeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to beholdJoeacc is a splendid one to behold
My 2003 CTT goes into the 230 range also. I feel a little uncomfortable with that range. I would rather see it pegged right at 180. Any other opinions on this? The thermostat should keep the CTT at one temp not all over like mine.
Old Jul 1, 2009 | 06:59 AM
rockitman's Avatar
rockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond reputerockitman has a reputation beyond repute
Your temperature sensor may be faulty. I had to replace my 2004 CTT temp sensor. It would go from 180 to the red very fast and throw a warning light. The temperature was in actuality just fine. Make sure you coolent level isn't low.
Old Jul 1, 2009 | 11:51 AM
bcherry's Avatar
thank you for the replies. I will definitely check everything referenced. I will update with results.
For the record, it does just fine (stays at 180) in all offroad situations. It is only under "track day" type driving that it fluctuates.
CoreyC2S
Nov 18, 2017 12:13 PM
hacellular
Aug 31, 2015 08:34 AM
PelicanParts.com
Aug 26, 2015 04:25 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
