Removing complete front Ash Tray?
Old Jul 10, 2009 | 10:32 AM
Darcski74's Avatar
Darcski74 is infamous around these parts
Cheers All,
First time poster long time lurker...So I managed to accidentally get a quarter stuck in between the back of the ash tray. Is there a way to remove it completely myself or should I take it into the dealership and have them do it? The problem is now I cant close the tray and its a bit annoying to have it open while I drive. Sorry for the lame 1st post better ones are yet to follow...
Old Jul 10, 2009 | 11:22 AM
ONE234's Avatar
ONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud ofONE234 has much to be proud of
i have done excatly the same with a 10 pence peice.
i had to use eye brow twesers to get in there and hook it out, not sure how it comes away from the console?
good luck.
does it come away by pressing down on it and pulling backwards?
Old Jul 10, 2009 | 12:46 PM
Reborn996's Avatar
Reborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to beholdReborn996 is a splendid one to behold
I have done this... but it requires removing the radio to access the two screws in order to get it out. FYI
Old Jul 10, 2009 | 05:11 PM
Darcski74's Avatar
good luck.
No it seems like its set in place! Its very frustrating Im almost embarrassed to have to take it in but I also don't want to have it open all day either... I'll try the tweezer suggestion tonight but like you said it required the radio to be pulled out which Im not sure how comfortable I feel doing that. Thank you for the suggestions...
Old Jul 11, 2009 | 10:11 AM
sparkhill's Avatar
sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !sparkhill Is a GOD !
Depending on where the coin is stuck, you can sometimes wrap a piece of duct tape sticky side out around something like a popsicle stick or wire and stick it to the coin. If you decide to try it, make sure you do not lose the tape too.
Old Jul 11, 2009 | 11:57 AM
Darcski74's Avatar
I think the coin a directly behind the ash tray...I do notice there are slots on the side of the console that feels like you can push something through, Im not sure it leads to the back of the ash tray though. I wish it were above it that way tweezers would do the trick. I'll try your option as well, Cheers.
Old Jul 12, 2009 | 09:15 AM
JBONDOx's Avatar
JBONDOx is infamous around these parts
edited
Last edited by JBONDOx; Jul 12, 2009 at 09:16 AM. Reason: it was bad humor, homless is no laughing matter
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
gulf gt
Aug 27, 2015 10:27 AM
The Oss
Aug 24, 2015 08:19 PM
