Need help/inputs painting my sealgray CS
I tried before, but did not get much help. So i try again, beeing a bit more clear this time.
My 05 sealgray CS´s paint is not very good. Next week i will have a guy painting it for me. I will tell him to paint it "lava gray" as the color is called over here. Meening the darkest grey the Cayenne 08 comes in.
What do you think? Will it be ok to paint the exterior in a say Lava grey but still keep the under the hood/inside of the doors and so on sealgray?
Calipers. I will have the guy painting my calipers red. Is there any particular color/name/code we should use?
Anything in particular we should think about in terms of what kind of color to use? I´m thinking about heat etc.
Or anything else regarding painting calipers?
thanks Peter
thanks Peter
thanks Peter
thanks Peter
Also, if you are going to get the calipers painted then make sure you get them professionally done. This means remove the caliper and have it masked, shot blasted, power coated and finally baked. A good caliper painter will also replace the PORSCHE decal with vinyl items and give the caliper a coat with clear laquer to protect it. This may also be an ideal opportunity to have them rebuilt with new seals etc.
Have a look here for an example;
http://www.design911.co.uk/fu/pt66_5...per--Painting/
Do not let anyone paint them with a brush, it will look pants and peel off with the heat these babys produce.
NC 996TT
Mar 23, 2023 06:19 AM
Bmw M3 Guy
Feb 21, 2018 09:29 AM
bongnation
Sep 25, 2015 02:58 PM
